Bilstein B6 shocks
cjensen
PostPosted: Sat Feb 08, 2014 1:14 am    Post subject: Bilstein B6 shocks Reply with quote
for my 931 S2 1983 i need a pair of bilstein B6 shocks for the front.
bilstein lists 2 different ones to fit
34-000403
and
34-001042
what is the right ones for my 931 ?
Christian Jensen
Denmark
931 S2 1983
PostPosted: Sat Feb 08, 2014 1:27 am    Post subject: Reply with quote
http://garage.ideola.com/prod-SuspensionUpgrades.html#Dampers
34-001042
cjensen
PostPosted: Sat Feb 08, 2014 1:56 am    Post subject: Reply with quote
http://bilstein.suspensiondirect.co.uk/Porsche-924-2.0_Turbo.jsp
bilstein list both ?
do you know the difference ?
Christian Jensen
Denmark
931 S2 1983
PostPosted: Sat Feb 08, 2014 2:48 am    Post subject: Reply with quote
That is a reseller site, and resellers that don't specialize in Porsche (much less the 924) frequently mis-label product. Note that all of the images are generic file images, and not the actual part. This is your first clue that something might be amiss.
According to several other sources I've looked at, the 0403 is a VW/Beetle strut insert, and not a rear shock absorber.
I would recommend using the 1042 product because we know for certain that it is the correct part for your car.
cjensen
PostPosted: Sat Feb 08, 2014 3:26 am    Post subject: Reply with quote
thanks for your answers.
http://www.ebay.co.uk/itm/301082803152?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
a good thing i didn't buy them cheap or not !
Christian Jensen
Denmark
931 S2 1983
Johann
PostPosted: Fri Dec 16, 2016 7:07 am    Post subject: Reply with quote
Reviving an old topic.
I am looking into replacing my shock absorbers. I have the following shock absorbers in my basket
Front: 34-001042
Rear: 24-001618
I am still strugling with two questions:
1) Can I keep my stock springs, or do I need to order a set of lowering springs. If so, What shoudl I get?
2) Will the front shocks slide into my existing struts, and do I have to cut modify anything? Or is 34-001042 a complete strut?
PostPosted: Fri Dec 16, 2016 7:38 am    Post subject: Reply with quote
No need for lowering shocks unless you really want a lower ride height.
34-001042 is a strut insert, not the entire strut housing + assembly.
Those inserts are direct drop in into OEM strut housings, but they do have a larger diameter; consequently, make sure to completely empty the old strut housing oil (used for cooling the strut insert), and replace it with a smaller amount of 10W40.
Johann
PostPosted: Fri Dec 16, 2016 8:24 am    Post subject: Reply with quote
Thanks Dan,
So, to make I understand you correctly. Is it just a matter of disassembling the existing strut, cleaning it out (with carb/brake cleaner?), dropping in the new insert with some 10W40 for lubrication and reassembling the strut?
PostPosted: Fri Dec 16, 2016 9:11 am    Post subject: Reply with quote
Johann wrote:
Thanks Dan,
Yes. Take the top nut off, remove old strut insert, dump old oil, clean, put in new oil (small amount), install new strut insert, install top nut. Done.
PostPosted: Sat Dec 17, 2016 12:18 am    Post subject: Reply with quote
Just to confirm
We can't use the Koni's with the stock springs? In this case (the '82) I am looking for the best compromise between performance and comfort. I would think adjust-ability helps with both?
PostPosted: Sat Dec 17, 2016 12:41 am    Post subject: Reply with quote
I know of no reason you can't use Konis with stock springs. The issue with Konis on the 931 is that the adjusting doohickey at the top will put a "reverse dent" in the NACA duct on the hood.
PostPosted: Sat Dec 17, 2016 3:11 am    Post subject: Reply with quote
hmmm, thats a bummer... even if you keep the white knob off when hood is down?
PostPosted: Sat Dec 17, 2016 4:15 am    Post subject: Reply with quote
Adjustment is for rebound only. The "shock" from hitting bumps, etc, cannot be adjusted out of Koni Sports.
You might consider Bilstein. I ran them on Shaggy and found them pretty good, and quite a bit less expensive if I recall.
Johann
PostPosted: Sat Dec 17, 2016 6:41 am    Post subject: Reply with quote
I have ordered the Bilsteins and will be replacing all the rubber in the front suspension as well.
I'll post pics as I progress
edalenta
PostPosted: Wed Jan 18, 2017 12:17 pm    Post subject: Reply with quote
I believe the difference is Compression/Rebound settings.
I found this info on one of the Bilstein websites:
34-000403
150/95
34-001042
150/120
No idea of the units (Pounds, Kilograms, Newtons, etc)
'87 924S - daily driver/project car
'91 535i - wife always gets the new car
