MikeDanger
Posted: Sun Jan 05, 2014 12:29 am Post subject: title change, Swapped WUR, now what? |
So I finally got the 81 931 engine back together. to replace the WUR. started at 1030 pm finished at 6am... and 33 deg inside the garage.
Well so now it idles, slight miss, But if I give it any gas it will die.
Unfortunately Im not sure If I put the vac hoses back correctly (if it matters)
Since I had to replace all the ones in the intake area.
theres the 3 with the T, : one goine to the WUR, one going to the diaphram, and one to the throttle(but i wasnt sure which nipple on the throttle)
And a seperate line going from the Coolant line(?) to the throttle. _________________ It was either this or a giant box of legos
Posted: Sun Jan 05, 2014 12:39 am Post subject: |
There should be a vacuum diagram on your inner fender, driver's side I think. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
MikeDanger
Posted: Sun Jan 05, 2014 12:45 am Post subject: |
so heres how it ran.
at first it started and ran for about 15 sec then died, but I think i had the frequency valve unplugged.
then a few more tries and it would run then sputter and die
couple more tries and it would start to idle a bit, then the slowly the irpms would drop. but if I went an opened the idle control screw it would seem to level out but eventually die.
couple more tries and it it eventrually began to idle and not die. BUT any touch of the throttle and it would die immediately.
(actually if I cracked the throttle a tiny hair, the rpms would go up slightly)
Also when i unplugged the overboost switch it dies immediatley. this seem to cut out the frequency valve. SO I grounded it, and would heave the frequency valve run for a second.
and yes Im considering the pressure valve tool, but then again I plan to go EFI, ASAP, i simply want to make sure the car runs and drives Ok before I mess with it.
Ok now Im going to catch up on my sleep! _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Sun Jan 05, 2014 12:48 am Post subject: |
| Grenadiers wrote: | | There should be a vacuum diagram on your inner fender, driver's side I think. |
oh thats worn off. but would that be a possible cause of the problem anyway? _________________ It was either this or a giant box of legos |
Posted: Sun Jan 05, 2014 1:26 am Post subject: |
What year car do you have? Many things can be the cause of your problem. The air/fuel mixture could be very rich or very lean for example. Check your plugs. The engine might be running only on the cold start valve, and then nothing. If a series one engine, the distributor might be set at a 'retard' position. Might have to pull your injectors and run a flow/volume test. Here's a link to a vacuum diagram for the series one engine.
http://www.924board.org/viewtopic.php?t=36134&highlight=vacuum+diagram _________________ '83 944 Track car.
Posted: Sun Jan 05, 2014 1:39 am Post subject: |
After replacing a WUR, one should always check the system and control pressures. Then the timing and mixture. _________________ White 87 924S "Ghost"
Posted: Sun Jan 05, 2014 3:14 am Post subject: |
In answer to your original query, line connection definitely matters.
Here is a diagram:
However, Paul is absolutely right. . .with a new WUR, system pressure and mixture will need to be returned to baseline using the correct tools or the car will never run right.
And yes, you do need to purchase specialty tools to work on your vintage Porsche turbo. _________________ Toofah King Bad
MikeDanger
Posted: Sun Jan 05, 2014 7:23 am Post subject: |
that diagram must be for an S1, where can I find one for an s2? _________________ It was either this or a giant box of legos |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
MikeDanger
Posted: Sun Jan 05, 2014 9:04 pm Post subject: |
Ok well it looks like my routing was right. The only spot im not sure of and the diagram is not clear on, is the throttlebody. One port on the TB is the tiny little vent that looks to be covered by the throttle plate.(the one sticking straight out 90deg) Now I dont know if it makes a difference. I have the line comming from the water tube connected to that one.(i think)
But it seems that if I do anything more than nudge the throttle by a half a millimeter the engine wants to die.
MikeDanger
Posted: Sun Jan 05, 2014 9:26 pm Post subject: |
I doubt its a fuel pressure problem. the CIS plate has resistance and it ran better BEFORE I pulled the intake off and replaced the WUR.
I dont think its running only on the cold start valve, as it seemed to be running better at it started to warm up.
One thing I found (before I started it) was the thermostat was broken. Now Im not sure is that means it was always open, or always closed and never going to open? either way I took it out.
however now I heard the frequency valve buzzing, while its running, where as I dont recall that before? But as i mentioned when I disconnected the Overboost switch the Freq valve would stop buzzing and the car would die.
(BTW, since my garage is several miles away, I have to plan/research ahead, then take the info and go work on it, so since its 15* outside I'm staying in and try and take my guesses in the mean time)
anyone in denver got a Pressure tester I can borrow? ( I honestly don't want to put much money into the CIS, since im working on my EFI/ITB system.
I kind of wonder if I have a vac leak somehwere, but still I think it would run a little bit with some throttle even with a leak, But I dont see where the leak would be I checked all the lines.
BUT seemed all the old lines were very brittle and pretty much snapped right off. so I replaced them, the only line left was the one from the water pipe going to control valve near the fender. _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Sun Jan 05, 2014 9:42 pm Post subject: |
also after the engine started to at least idle, I pushed on the CIS plate a tiny bit and again the engine wanted to die _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Sun Jan 05, 2014 9:50 pm Post subject: |
Oh also to throw more into the mix. I just remebered. I put the WUR from the 80 model (into this 81) I read that it was acceptable and would have more enrichment (or something) and was commonly done, so since i wanted to up the boost I figured it should be ok. But either way it should run with it obviously. _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Mon Jan 06, 2014 2:16 pm Post subject: |
any other thoughts here? what else could have changed? any tests I can do to rule out things? _________________ It was either this or a giant box of legos |
scriblz7
Joined: 07 Dec 2008 Posts: 112 Location: kirkland WA.
