Picture of turbo down pipe?
MikeDanger
PostPosted: Mon Dec 16, 2013 5:55 am    Post subject: Picture of turbo down pipe? Reply with quote
can anyone show me a picture? if its off the car, then hopefully in the upright position. so I can see what I need to make one, in the proper oreintation.
PostPosted: Tue Dec 17, 2013 4:19 am    Post subject: Re: Picture of turbo down pipe? Reply with quote
These are the best pix I could find of the main downpipe.
I might have a good used condition down pipe if you'd be interested. Won't be able to confirm availability until Thursday or Friday.
MikeDanger
PostPosted: Tue Dec 17, 2013 4:58 pm    Post subject: Reply with quote
thanks, however Ill be making my own 3" exhuast.
I dont like how the factory pipe has a lot of kinks in it. and I wont be tying in the WG.
I just need to see what tubing/bends I need to collect. I dont like the 90deg down turn coming out of the turbine. would like to see if I can straighten it out a bit
so can you tell me if this will fit?:
http://i.ebayimg.com/t/4-BOLT-T3-X-3-Inch-HIGH-FLOW-Turbo-Turbine-Housing-Outlet-V-Band-Flange-Adapter-/00/s/NDc4WDQ4MA==/$T2eC16RHJHQE9nzEzL-SBQ9,z!PY8g~~60_12.JPG
[img]http://i.ebayimg.com/t/4-BOLT-T3-X-3-Inch-HIGH-FLOW-Turbo-Turbine-Housing-Outlet-V-Band-Flange-Adapter-/00/s/NDc4WDQ4MA==/$T2eC16RHJHQE9nzEzL-SBQ9,z!PY8g~~60_12.JPG[/img]
