Whining noise after belt change
PhoenixOO10
PostPosted: Sun Nov 17, 2013 12:50 pm    Post subject: Whining noise after belt change Reply with quote
I just changed the timing, balance, air conditioning, and power steering belts along with all the rollers. I now have a constant whining noise. Could this be caused by the balance shaft belt going over one of the toothless rollers?
1988 924S - everyday driver.
PostPosted: Sun Nov 17, 2013 1:28 pm    Post subject: Reply with quote
2.5 engine definitely has some belt noise.
Drive on!
PhoenixOO10
PostPosted: Sun Nov 17, 2013 2:08 pm    Post subject: Reply with quote
Thanks for the quick reply!
PostPosted: Fri Nov 22, 2013 11:51 pm    Post subject: Reply with quote
No belt whine on a 2.5 is a bad sign. When you get used to hearing your engine before and after a belt re-tension you will come to know the correct whine. When the belt job gets alot of miles on it and she is getting loose the whine becomes barely audible. So be happy it is whining.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
