ggrecian
Posted: Thu Nov 07, 2013 8:54 pm Post subject: PLEASE HELP 924s porsche Fuel injector pulse |
1987 porsche 924s crank no start.have spark.tach bounches when cranking.have fuel pressure to the rail.fuel injector do not show pulse with noid light.with multimeter both plugs have voltage on fuel injector electrical connector.PLEASE HELP!!!should i get voltage on both injector plugs?how to fix or diagnose no injector pulse? _________________ porschelover |
Posted: Fri Nov 08, 2013 2:07 am Post subject: |
This might help
http://www.clarks-garage.com/shop-manual/ts-01.htm
Its just an early 944, so there's lots of documentation available on how to diagnose the 944 EFI system.
Typically injectors are instructed to fire by the computer based on the computer receiving proper signals from various sensors on the engine. If those signals are not received or not in the proper specification and it will not fire the injectors for safety reasons. _________________ Stefan
ggrecian
Posted: Fri Nov 08, 2013 2:56 am Post subject: |
Thanks much!clarks garage definately has a Wealth of information.which sensor would u start with..tach hops so does that mean the speed and reference sensors are good?alsoi accidently swapped the speed and reference sensor plugs.could that have damaged computer? _________________ porschelover |
ggrecian
Posted: Fri Nov 08, 2013 3:00 am Post subject: |
Tach hops when cranking..so does that mean that the reference and speed sensors are good? _________________ porschelover |
Posted: Fri Nov 08, 2013 3:14 am Post subject: |
No idea. Neither of my cars use them, so I'm out of my depth.
From what I understand, the sensors are interchangeable? If so, I doubt that it could cause ECU damage, but I've been wrong before (and will again! heh)
Might check over on the Pelican Parts forum where there is more traffic and potentially more answers. _________________ Stefan
Posted: Fri Nov 08, 2013 6:48 am Post subject: |
Did you measure pressure on the rail, or just basing it on the fact that fuel is in there? I might try a known good DME if you have one available.
Oh, and swapping those sensors should not hurt the DME. _________________ Toofah King Bad
ggrecian
Posted: Fri Nov 08, 2013 6:59 am Post subject: |
yes have 37 psi when cranking.any other ideas _________________ porschelover |
