High idle after startup
xanderdeg
PostPosted: Tue Nov 05, 2013 9:24 am    Post subject: High idle after startup Reply with quote
After starting my engine warm, it's idling at around 1500rpm. After driving for a bit it idles just below 900rpm and it's a little shaky sometimes.
Not sure what is causing this, maybe my AAV is stuck?
PostPosted: Tue Nov 05, 2013 9:26 am    Post subject: Reply with quote
The idle bypass system is based on temperature and isn't the fastest to respond after power is applied.
Worth a shot to clean it out and give it a good test.
larchie
PostPosted: Tue Nov 05, 2013 12:18 pm    Post subject: Reply with quote
Did the high idle when warm just suddenly occur or was there work done prior to the issue? Lots of possible factors but it might be worth checking first for vacuum leaks, auxiliary air valve operation or leaks, and the auxiliary air regulator and its supply voltage.
!tom
PostPosted: Tue Nov 05, 2013 12:40 pm    Post subject: Re: High idle after startup Reply with quote
I'd expect a stuck AAV would give the opposite symptoms.
Could be a bad WUR; it's tuned to be rich enough so that it starts, and when it's warm, it's overly rich causing the drop in RPM.
78 924 NA
5-lug
xanderdeg
PostPosted: Tue Nov 05, 2013 1:43 pm    Post subject: Reply with quote
What's a WUR?
And I'm not sure if that would cause such high idle after warm starts but that's only my uneducated guess...
It was doing it a little before but nothing as high as it does now.
I've checked for vacuum leaks and there don't seem to be any. Will check again as well as the AAV and AAR. Thanks.
larchie
PostPosted: Tue Nov 05, 2013 1:51 pm    Post subject: Reply with quote
I could be wrong but my understanding is that when the engine is warm the normally operating auxiliary air valve is closed. If not, it should be cleaned, fixed, or replaced. On the other hand, if the idle is high and clamping a hose to the auxiliary air valve causes the idle to drop, then the auxiliary air valve is open and thus defective. So if the valve doesn't close all the way when warmer, then the idle would be higher than normal. On many cars, there's a small nut on the side that can be loosened and then moved to adjust the valve and increase or decrease the idle speed.
So if I am mistaken in my understanding (as I often am!), and as !tom expects the idle to decrease, I think it's still worthwhile to check the auxiliary air value as cracked hose or dirty valve can result in an irregular idle on these cars.
Certainly the warm-up regulator could be a factor, but I understood xanderdeg to say the idle was high after starting when the car was warmed up. Only later, after driving some, the idle dropped.
