New owner... Need a shop and some advice.
motogonzo
PostPosted: Wed Oct 02, 2013 10:59 am    Post subject: New owner... Need a shop and some advice. Reply with quote
I'm a previous 928 owner and I have been longing for another porsche ever since a Prius totaled my beloved ride. I'm not trying to spend a ton of money right now, so I thought a 924 would be manageable.
I just bought a 1987 924s with ??? miles on it. The odometer is broken as I discovered after I bought it. It's clean and I love it already. It has a number of little issues that I think I can handle, but also a few I don't know how to approach.
I thought 924s didn't have power steering, and this car feels like it doesn't, but then I learned through a lot of forum reading that I am supposed to have it... Not sure where to start with that.
As long as I have the dash off to fix the odometer, I want to sort out the issues with the heater. I did a lot of forum searches but didn't get much closer to an answer. The fan volume knob connects to nothing. It doesn't appear to be snapped, but I think a female part is missing from the heater switch. Aside from that... When I'm driving, hot air comes out the front vents, but I can't get it to come out the defroster, which is what I really need. How convoluted is the heater system? Is it possible/not too expensive to fix?
Assuming I can't do it, are there any places in Southern California that really know the 924? I'd love a recommendation.
The other major issue is that it eats fuel like crazy. I don't know whether to look for a cracked line or if something is wrong with the fuel system.
And it gets frighteningly hot in traffic.
And the sunroof doesn't work and I have no idea where I am supposed to actuate the hatch release motor if it even works.
emoore924
PostPosted: Wed Oct 02, 2013 12:08 pm    Post subject: Reply with quote
Welcome to toofah ownership and congrats!
Your car is essentially a 944 in 924 bodywork. That's a good thing. You get more hp than the rest of us, and later running gear. If you find someone who knows 944s you're in luck for most of the mechanicals on your car.
I'd pop over to Pelican and check in there. There are folks here who can help with the 924s but I think you're more apt to find knowledgeable 944 folks there.
Oh, and BE SURE you know the last time the timing belt was changed. If you do not know, or if it was more than 30k miles or (I think) 3 years, I would PARK the car until you have the work done. The do fail and when they fail, you wipe out the top end of the motor. BTW, belt change is probably not a DIY job because of the need to properly tension the belt (there are LOTS of opinions on this -- see Pelican).
Again, Welcome!
motogonzo
PostPosted: Thu Oct 03, 2013 12:49 am    Post subject: Thanks Reply with quote
Thank you. So I guess I should get a Haynes manual for the 944 engine and another for the 924 chassis? I'll check out pelican.
PostPosted: Thu Oct 03, 2013 1:34 am    Post subject: Re: New owner... Need a shop and some advice. Reply with quote
Welcome! We'll try to get you squared away. The Odometer gear is a common failure point, they are available online and aren't too bad to repair. The key apparently is to not reset the trip meter while the car is on the move, though realistically the plastic just fails overtime.
Power steering pumps and hoses leak and then fail, a common 944 failure issue. A reseal kit for the pump is fairly cheap and easy to do. Replace the hoses for the reservoir and the reservoir itself and fill with fresh ATF (not power steering fluid). Some owners choose to disable the power steering system and remove the pump, etc.
Here's a video on rebuilding the pump: http://www.youtube.com/watch?v=PsZOhqSfy-Y
Here's a good post on how to repair a common failure point in the heating system for the early 944's: http://www.944foot2thefloor.blogspot.co.uk/2009/09/how-to-repair-heater-control-valve-on.html
I wish I knew someone in SoCal that could help you, hopefully someone here or on one of the other Porsche sites might, (PelicanParts has a great forum, there is also Rennline and 944online)
The EFI system used on the 924S and 944 is pretty basic and simple to work on. Try cleaning the MAF sensor and verify that there aren't any vacuum or intake leaks anywhere in the engine bay. If that fails to improve the mileage, then check your injectors for leaks and many of the sensors for issues. Changing the fuel filter and checking the fuel lines is a good first step as well, since leaking fuel lines in the engine bay are not good due to Porsche running them over the hot exhaust.
Make sure your undertray is in place (available from Porsche still) I would flush the cooling system and bleed it properly, then verify the cooling fans come on properly. Might not be a bad idea to look at having the radiator and hoses replaced if a flush/bleed doesn't fix it.
There should be a button on the center console to actuate the motor. This might help: http://www.944foot2thefloor.blogspot.co.uk/2010/07/how-to-repair-sunroof-on-porsche-944.html Also: http://www.clarks-garage.com/shop-manual/body-03.htm
There are more great tutorials here:
http://clarks-garage.com/shop-manual/repair-procedure-index4.htm
http://944foot2thefloor.blogspot.com/p/tutorials.html
http://www.pelicanparts.com/944/944tech_articles.htm
motogonzo
PostPosted: Thu Oct 03, 2013 2:19 pm    Post subject: Reply with quote
Thanks so much for the detailed reply. Really helpful.
I figured out that it's leaking fuel from the tank today. I am not too happy about it. Is it even worth trying to fix?
!tom
PostPosted: Thu Oct 03, 2013 4:59 pm    Post subject: Reply with quote
Common problem.
I discussed my saga here. Includes the final solution, which was a failed fuel sender gasket, as well as a rotten fuel filler vent hose.
78 924 NA
5-lug
PostPosted: Fri Oct 04, 2013 12:10 am    Post subject: Reply with quote
Tanks are repalceable and the plastic ones are known to fail. When you order a replacement, order replacement vent and filler hoses while you're at it.
