Cooling fan resistor
Dean47
PostPosted: Sat May 25, 2013 8:49 am    Post subject: Cooling fan resistor Reply with quote
I have a 1977.5 924 na. Can I bypass the cooling fan resistor or would that cause other problems? Fan turns very slow unless I bypass it.
Ozzie
PostPosted: Sat May 25, 2013 5:43 pm    Post subject: Reply with quote
The bypass is supposed to happen via a relay when the ignition is on.
Check the relay first.
Its AUTO and its BLACK
Montego Black on black/red
Dean47
PostPosted: Sat May 25, 2013 10:46 pm    Post subject: Reply with quote
Ok thanks, fan stopped working altogether unless I bypass resistor. Would it be ok to relocate resistor cause it is always wet when it rains, or does that matter
PostPosted: Sun May 26, 2013 12:40 am    Post subject: Reply with quote
The fans when the ignition is on have two paths to ground, one through the relay which is a low resistant path and one through the resistor.
When the ignition is off the fans only have one path to ground through the resistor. This allows the fans to run slower and quieter when the car is parked and the radiator fan switch is calling for cooling.
Dean47
PostPosted: Sun May 26, 2013 1:54 am    Post subject: Reply with quote
Grounds are all good. ( first thing I checked) fan only works if I bypass resistor car running or not. I don't care about the noise so would it be ok to replace relay and just bypass resistor?
PostPosted: Sun May 26, 2013 2:15 am    Post subject: Reply with quote
Replacing the relay will probably fix it, no need to bypass the resistor.
Dean47
PostPosted: Sun May 26, 2013 2:50 am    Post subject: Reply with quote
Thanks for your help. I can re build motors, but I've never been good with electronics! This is off the subject but how do I put up a pic of my car by my name like everyone else? I know stupid question!
Mudd
How about replacing the resistor. My resistor on my 78 discintegrated because of its location above the radiator. The replacement was pretty cheap.
1987 944
Dean47
PostPosted: Sun May 26, 2013 2:56 am    Post subject: Reply with quote
I'll replace resistor too then and relocate it's in a bad spot water soaks it everytime it rains or I wash it
Ozzie
PostPosted: Sun May 26, 2013 8:04 am    Post subject: Reply with quote
I am not sure about the early models but I cant see that it would be any different.
The relay is wired around the resistor and uses the same path to earth on later models through the rad switch and fan.
PostPosted: Sun May 26, 2013 9:08 am    Post subject: Reply with quote
2 paths, one through the relay and one through the resistor. J26 is the relay, V7 is the fan motor, N39 is the resistor, and F18 is the radiator fan switch. Note there are separate fuses. You are correct the relay and the resistor is on the + side of the fans.
Dean47
PostPosted: Sun May 26, 2013 9:25 am    Post subject: Reply with quote
Thank you that was very helpfull, I understand it now. Thanks
