Mudd
Joined: 27 Aug 2012 Posts: 78 Location: Cincinnati,Ohio
Posted: Mon May 27, 2013 11:28 am Post subject: CIS Test kit |
Where can I get a CIS Test kit for ky 924, and is there a specific brand to look for. From what I have reading the one from harbor freight is no good. _________________ 1978 924
1987 944 |
B
Posted: Mon May 27, 2013 12:15 pm Post subject: |
try here
http://garage.ideola.com
I bought a kit from Dan and it worked out well
Sean _________________ 1979 924 n/a
BAE turbo
5-speed snailshell |
Mudd
Posted: Mon May 27, 2013 1:06 pm Post subject: |
I don't see the CIS kit on Dan's site. _________________ 1978 924
1987 944 |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon May 27, 2013 4:51 pm Post subject: |
Probaly hid it so you have to go through his hole site to find it ....
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1998 Nissan Silvia ... sons back from OS he has taken it
BIG BLOODY MOTORHOME 300zx Sold
1980 Fire truck Sold |
SlayerSST
Posted: Tue May 28, 2013 5:36 am Post subject: |
I tried ebay and pelican and they are both sold out.
Here is the part number.
TA 33865 |
Posted: Tue May 28, 2013 11:58 pm Post subject: |
I've stopped selling the Hoffman TU-14C test kits because the sources were too unreliable and people were getting ticked off when I didn't have them in stock. JC Whitney used to carry them, might check there. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed May 29, 2013 2:25 pm Post subject: |
Amazon as well. _________________ Toofah King Bad
scm924s
Joined: 22 Oct 2010 Posts: 296 Location: Gloucester UK
Posted: Wed May 29, 2013 4:40 pm Post subject: |
Not difficult to make yourself, I made one from parts readily available in UK.
Here is one from a US VW site -
You can't effectively test fuel pressure without a fuel pressure gauge. Otherwise, troubleshooting is guesswork. Making and using the gauge is very easy. There is no excuse NOT to test your fuel pressure when experiencing problems with your car such as cold starting, hot starting, rough idle, stalling, won't start, etc. The ONLY hang up you may have with making this contraption is finding the METRIC fittings (12MM diameter with 1.5 thread). We get ours from M & W Hydraulics here in Tampa. It may take some creative CIS scrapping to get the fittings together that you need, but you'll get it together! I'm sure. I've got faith in you!
Your fuel gauge will have a 12MM X 1.5 female fitting on one end. This will screw into the fuel distributor at the point where the fuel line that goes off to the control pressure regulator is currently screwed in. You will need the fitting to be attached to a fuel line that will withstand high pressure (80PSI+). The other end of this fuel line is then fitted to a T fitting. Off of one of the fittings on the T, you will screw in a pressure gauge. The remaining fitting on the T will lead off to a gate valve. The gate valve will then lead off with another piece of fuel line that will then have a male 12MM X 1.5 fitting on it that the car's fuel line going to the control pressure regulator will screw onto. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
Mudd
Posted: Thu May 30, 2013 11:36 am Post subject: |
I found a CTA 3420 Bosch K jetronic CIS fuel injector pressure tester for $110 on Amazon. Is that what I need. _________________ 1978 924
1987 944 |
Mudd
1987 944 |
Posted: Thu May 30, 2013 12:52 pm Post subject: |
Yes _________________ White 87 924S "Ghost"
