dual turbos
Joined: 10 Sep 2012 Posts: 14 Location: Spring Grove IL
Posted: Sun Apr 07, 2013 8:58 am Post subject: 931 on the way back |
Finished replacing my transaxle today, it was not too bad of a job. I had a little trouble aligning the spline coupler, but other than that just had to do the labor. Took it for a test drive, the first time out with a new clutch and it shifting properly and wow this car is quick! It kind of stalled out on my second trip around the block, I had a hard time starting it. I'm going to replace the gas filter and put another dose of fresh gas thru it, hope that will straighten it out. It's running a bit inconsistent yet. Then onto the next big project, fixing the burnt interior blower fan wires. I was wondering if it would be easier to take apart the whole interior and then work on the wiring harness, or just tough it out under the dash. _________________ Dual Turbos |
