xanderdeg
Joined: 08 Jul 2012 Posts: 286 Location: Vancouver, BC, Canada
Posted: Thu Apr 04, 2013 6:27 am Post subject: dipstick seal? |
| My dipstick has no seal so it leaks oil out of the hole as I drive. Does anybody know the part number for the seal? Or something I could use as a replacement? |
!tom
Posted: Thu Apr 04, 2013 3:32 pm Post subject: |
Sounds like you've got bigger problems. Your crankcase should be vented to your airbox. Your crank breather must be blocked in order for you to be leaking oil out around your dipstick. _________________ 78 924 NA
5-lug |
xanderdeg
Posted: Thu Apr 04, 2013 3:35 pm Post subject: |
| I hooked up a brand new breather hose just 2 months ago! I guess I'll check it again for blockage... |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
Posted: Thu Apr 04, 2013 10:01 pm Post subject: |
Can I ask where you got the breather hose?
These are no longer available here, I tried many different sources.
It is a very special hose with a small restrictor inside. _________________ 1983 NA Alpineweiss since 2001
Peugeot 205 Generation |
Posted: Fri Apr 05, 2013 1:31 am Post subject: |
Good hardware store should have an oring that will fit, if you walk in with it.
Oh, and +1 on your excessive crank pressure. Compression test may be in order. _________________ Toofah King Bad
xanderdeg
Posted: Fri Apr 05, 2013 1:37 am Post subject: |
| ... I made my own with some fuel hose and PVC elbow joints... Couldn't find one either so I just did a DIY. |
xanderdeg
Posted: Fri Apr 05, 2013 1:49 am Post subject: |
| Compression test to be conducted this weekend, fingers crossed.... |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Sat Apr 06, 2013 9:40 pm Post subject: |
Not sure, but havent I read somewhere that your dipstick has to have a good seal for the EFI to work properly ??
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
xanderdeg
Posted: Sun Apr 07, 2013 3:30 am Post subject: |
Well I guess its a good thing that I don't have efi  |
Ozzie
Posted: Sun Apr 07, 2013 7:41 am Post subject: |
Oil breather hose can be any oil resistant hose, just jam a piece of broom handle in it with a 6mm hole in the centre. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
