German Godzilla. The creation of a (2-tone) Green Monster...
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13  Next
PostPosted: Thu Mar 24, 2016 2:33 am    Post subject: Reply with quote
PRICELESS !!!
Good to have you on this board brother !
WEASEL149 wrote:
...and become a plenum inlet diffuser:-
Set to 'blow' versus 'suck'
PostPosted: Thu Mar 24, 2016 4:00 am    Post subject: Reply with quote
PostPosted: Thu Mar 24, 2016 4:55 am    Post subject: Reply with quote
WEASEL149
PostPosted: Tue Mar 29, 2016 8:29 am    Post subject: Reply with quote
Spaceballs - awesome film
1979 UK 932
WEASEL149
PostPosted: Tue Mar 29, 2016 8:42 am    Post subject: Reply with quote
The 'Hoover' welded pretty good for a cast piece:-
Diffuser slot cut and just needs smoothing/blending:-
Chargecooler fitting underway - making an aluminium cradle:-
Chargecooler roughly in place:-
The small alternator in the pics is a 70A Denso weighing 2.8kg.
I have to check engine movement when it's fired up and may need to slot the charge cooler cradle fitting attached to the alternator bracket.
Hopefully this is enough pics to keep you guys happy.
I'm now trying to work out which way to go with the engine coolant radiators and the charge cooler radiator.
I think I'm going to make the badge panel removable as others have done.
1979 UK 932
PostPosted: Tue Mar 29, 2016 10:05 am    Post subject: Reply with quote
Damn outstanding.
PostPosted: Tue Mar 29, 2016 6:11 pm    Post subject: Reply with quote
this is going to be one fast 924
red 924 and not red 924
WEASEL149
PostPosted: Sun Feb 26, 2017 11:13 am    Post subject: Reply with quote
Update...
New charge cooler rad/heat exchanger:-
Chosen for large surface area but only ~17mm thick so it won't block airflow to the main rads.
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:15 am    Post subject: Reply with quote
Pic of new engine cooling rad. Two of these to cool head and block:-
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:18 am    Post subject: Reply with quote
Pics of new cooling cradle arrangement:-
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:24 am    Post subject: Reply with quote
Cooling assembly fitted to car:-
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:28 am    Post subject: Reply with quote
3" exhaust now complete:-
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:31 am    Post subject: Reply with quote
You want more, ok...
New cross member for the electric water pumps:-
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:33 am    Post subject: Reply with quote
Work underway to complete the inlet manifold and throttle:-
1979 UK 932
WEASEL149
PostPosted: Sun Feb 26, 2017 11:35 am    Post subject: Reply with quote
New vacuum manifold and used Bosch charge cooler pump - this may not get used as I've come up with a better alternative:-
1979 UK 932
Page 11 of 13
