Car runs great, but some odd issues
Goto page Previous  1, 2, 3
PostPosted: Sat Mar 02, 2013 12:14 am    Post subject: Reply with quote
CorsePerVita wrote:
Another issue I forgot to mention... the windshield wipers randomly turn on. Sometimes when I turn on the turn signal, other times when I turn. Not always... sometimes. So something is loose or I have a short somewhere.
Not sure if there`s variation between models (there is with stalk switch) or the condition of your switch anyway BUT that problem is caused by intermittent poor grounding of whatever wiper relay terminal ( cant recall ATM or bother searching) needs to be grounded VIA the wiring, stalk switch and steering bearing/ retainer/ shaft, to stop the wipers.
There is a post by Smoothy that details the issue and the fix of earthing the steering shaft. Sounded a bit of a dodgy fix to me initially but after limited success cleaning, tightening, star washers under stalk screws, etc, went the same way. scraped paint off of lower steering shaft, attached a foot or so of soft, flexible, multi strand wire with a hose clamp and bolted the other end (fitted with suitable terminal) to ground. Fixed!
Allan @ DTA wrote:
CorsePerVita
PostPosted: Tue Apr 02, 2013 2:48 pm    Post subject: Reply with quote
The smoothie fix seems to have done the trick!
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
CorsePerVita
PostPosted: Wed May 15, 2013 3:12 am    Post subject: Reply with quote
Figured I'd update this. The fix seemed to help a lot, but the issue returned in the form of a hunting idle instead of just dying all the time. Upon inspecting the O2 sensor it was disconnected and the wire was covered in oil and just looked nasty.
I removed the crap wiring, installed a new O2 sensor. Heat shrinked the wiring for protection. Hasn't stumbled, had a rough idle, or died once at all since the 2 above fixes.
It's like butter!
- 1999 Ducati 900SS
Page 3 of 3
