crow.magnum
Joined: 13 Oct 2007 Posts: 50 Location: SOMERSET ENGLAND
Posted: Sun Feb 17, 2013 3:06 am Post subject: high idle and missing |
hi, ive got a 1980 931 .
its not been driven for a few month. so today i took it out.
started first time , but it idles at 1200 rpm and when i drove it it had a severe missing problem .
any ideas where to start?? |
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Sun Feb 17, 2013 3:41 am Post subject: |
Vacuum lines. Check them all. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
crow.magnum
Posted: Sun Feb 17, 2013 7:09 pm Post subject: |
| Ok whats the best way to find an air leak |
crow.magnum
Posted: Sun Feb 17, 2013 7:54 pm Post subject: |
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
Posted: Mon Feb 18, 2013 2:07 am Post subject: |
Since it is missing and has a high idle, I would check the intake to cylinder head gaskets first. Try spraying a mist of water on each vacuum area and listen for a change in the idle and look for white exhaust smoke.
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Mon Feb 18, 2013 3:01 am Post subject: |
Best way to find intake leaks is with a smoke machine. Worth a couple of bucks to have a mechanic do this. _________________ Toofah King Bad
crow.magnum
Posted: Tue Feb 19, 2013 1:03 am Post subject: |
Whats going on with this car
I checked for air leaks , I tweeked the intake bolts all were fine. Started the car it idled 1000 rpm. Took it down the road missed real bad turbo would not kick in just made some kind whineing noise . Got home car idled 1500 rpm flipped bonnet had steam coming up for exhaust area and the battery has started to leak acid . Are these all connected or am I on a a roll of bad luck .  |
dpw928
Posted: Tue Feb 19, 2013 1:23 am Post subject: |
The battery may have an internal short which could cause low voltage and poor spark. Was the steam from the exhaust caused by the battery acid?
78 928 5 sp Silver
crow.magnum
Posted: Tue Feb 19, 2013 1:37 am Post subject: |
| No the battery is on the oppisite side |
dpw928
Posted: Tue Feb 19, 2013 1:55 am Post subject: |
Forgot about the right hand drive. Are there any heater hoses in the vicinity of the exhaust that could be spraying coolant?
78 928 5 sp Silver
crow.magnum
Posted: Tue Feb 19, 2013 2:07 am Post subject: |
| No coolant hoses that im a whare of only the turbo and a breather hose |
dpw928
Posted: Tue Feb 19, 2013 2:21 am Post subject: |
You may want to check for an oil leak at the cam cover or the oil line feed to or from the turbo.
78 928 5 sp Silver
Posted: Tue Feb 19, 2013 3:08 am Post subject: |
Did you check the charge pipe coming directly off the turbo? Pull up on it and make sure the bracket hasn't come loose or broken. _________________ Toofah King Bad
crow.magnum
Posted: Tue Feb 19, 2013 3:24 am Post subject: |
| Its all tight and secure |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Tue Feb 19, 2013 4:02 am Post subject: |
| crow.magnum wrote: | | Got home car idled 1500 rpm flipped bonnet had steam coming up for exhaust area ( |
Did it smell like coolant or oil? Hopefully it didn't smell like fuel, which could explain the poor running.
Before you posted this I would have said maybe the AAV is stuck open. _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
