serzas
Joined: 20 Nov 2012 Posts: 52 Location: Lithuania, Europe
Posted: Mon Jan 07, 2013 12:19 am Post subject: Q: front spring rates and size |
hi, need some info about 931 front springs - anyone have one not in use?
full height when dissasembled, height on car under it's weight, coil diameter at bottom and top, if different, and spring rate. Is it the same as 924 NA?
 _________________ Porsche 931 1980 widebody CS / no, stock again
ex Porsche 944 1984 turbo look
ex Porsche 924 1982
ex Porsche 924 1978 |
Posted: Tue Jan 08, 2013 6:34 am Post subject: |
My na and turbo had same springs, whats your plan? _________________ 1980 924 Turbo
serzas
Posted: Wed Jan 09, 2013 12:34 am Post subject: |
That's essentially what I did. Cheap adjustable spring perch sleeves and top hat. 2.5" x 8" racing springs at 325lb (with 28mm rear torsion bars and KYB's) Though, I think the front rate is too much for my car at the moment as the front of the car is severely lightened and I'm running KYB's which generally suck.
http://www.planetspring.com/pages/compression-spring-calculator-coil-calculator.php
I used this on the Weltmeister lowering springs that came on my car to come up with an approximate 220lb/in rate. _________________ Stefan
Joined: 05 Jun 2006 Posts: 1489 Location: Ontario, Canada
serzas
Posted: Wed Jan 09, 2013 3:28 am Post subject: |
yep, the kit is OK, just 210$ with shipping and no fun with DYI is the solution for lazy people
and it not guarantees, that I would like how those springs will behave. as my car is a bit lighter than stock, I want to play around with several setups and see what's best for our roads and my weight _________________ Porsche 931 1980 widebody CS / no, stock again
ex Porsche 924 1982
Posted: Wed Jan 09, 2013 3:51 am Post subject: |
Luckily those springs are pretty universal. You'll have to experiment with different spring rates to get the desired rate. 2.5" diameter springs are available in any number of locations.
Here's a list of stock spring rates used on the 924/944/968 chassis:
http://www.clarks-garage.com/shop-manual/susp-15.htm _________________ Stefan
Posted: Wed Jan 09, 2013 7:05 am Post subject: |
Check out rallydesign uk, cheapest coil over sleeve ive found, works great. I have 60N/mm springs up front and 28mm rear bars. Works perfectly, but its very easy to fine tune the balance with adjustable weltmeister swaybars:-) . Spring rate choicewill severely depend o weight distribution and tyre sizes/stiffness, in general, and ofcourse what your dampers can handle. These spring stiffnesses we are talking about are relatively soft compared to a race car, so we wont be near the upper limit.. _________________ 1980 924 Turbo
serzas
Posted: Mon Jan 14, 2013 3:43 pm Post subject: |
the end result is this - a small cat size lowering kit with Audi 100 / A6 / C4 rear springs, which are 12cm at the top (fits original plates) and 33 cm heght, should be shorter than original ones. Will make even shorter, to have space for adjustment. as an option - OK. will try will see how ride will be.
ex Porsche 924 1982
