1.8T 924
steve924
PostPosted: Sun Dec 30, 2012 10:28 pm    Post subject: 1.8T 924 Reply with quote
Been working on putting a 1.8t (aeb code as the only one with the oil pump at the rear) in a 924 na, it requires lots of fabrication.
it uses a 944 s2 gearbox and torque tube, a ford clutch disc and a mk4 golf gti solid flywheel.
Bottom end in, this is just a get me going engine, if it all works ok a decent tuned engine will be fitted. it mounts at the original mounting points
oil pan is made from a mk1 golf, needs to be deeper at the back etc
starter is fitted upsidedown for clearance, the transmission tunnel still needs a bit of chopping.
next issue is the inlet (from a mk4 golf) needs abit of adjustment to clear the servo
Porsche 924 na
porsche 924 1.8t
FJ40Jim
PostPosted: Mon Dec 31, 2012 5:42 am    Post subject: Reply with quote
The intake from a B5 passat/A4 might be a bolt-in fit, since they are mounted longitudinal and have to clear the similar brake booster.
Underhood pic stolen from passatforum:
the_mad_electrician
PostPosted: Thu Jan 03, 2013 1:08 pm    Post subject: Reply with quote
Awesome. I can't wait to see how this one turns out.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
the_mad_electrician
PostPosted: Thu Jan 10, 2013 9:15 am    Post subject: Reply with quote
I'm not trying to start a fight but I think it might be possible to use one of the versions that has the front oil pump that is belt driven and possibly use a custom pickup tube. I'm just bouncing ideas around because I'm interested in doing the same swap. AEB 1.8 are the hardest version to come by around here.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
steve924
PostPosted: Fri Jan 11, 2013 9:10 am    Post subject: Reply with quote
If it works it would give you a better selections of engines, (golf one has a forged crank) just make sure it has a pilot bearing as some don't, most of the "other 1.8t's" seem to have a chain driven oil pump siiting right at the front of the engine. On mine the bottom of the block is close to the crossmember and there is about 1 to 2 inch clearance with the bonnet.
The hardest part of mine is the inlet, i've had to shorten a golf one and now the throttle body needs a bit of work to fit.
Here's whats been needed to fit so far:
custom engine mounts
modified sump
think it was a lightly modded audi 80 diesel oil pickup
modified mk1 golf gti windage tray
reshaped transmission tunnel
custom starter mounts (needs to be upside down very simple)
mk4 golf belhousing and adapter plate and dust sheild (the passat one might of been a better choice??)
modified rear coolant mount
remote oil filter
heavily modified mk4 golf inlet
custom water pipes
None of this was difficult (inlet aside), keeps me busy
still a few more bits to do
Porsche 924 na
porsche 924 1.8t
steve924
PostPosted: Fri Jan 11, 2013 9:38 am    Post subject: Reply with quote
Forgot to mention FJ40JIM Itried the passat one a while ago but it hit the brake master cylinder, shame as its a much better casting than the golf one.
Porsche 924 na
porsche 924 1.8t
the_mad_electrician
PostPosted: Fri Jan 11, 2013 10:05 am    Post subject: Reply with quote
Did it hit the booster or the master cylinder itself? If it is the booster maybe a BMW one would work
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
steve924
PostPosted: Wed Jan 23, 2013 12:28 am    Post subject: Reply with quote
The standard inlet hits both booster and brake cylinder, the passat one has the throttle body right where the brake cylinder would be so a golf one chopped up does the trick.
A little more done
Had to move the turbo outlet as it points at the frame rail initially.
Porsche 924 na
porsche 924 1.8t
the_mad_electrician
PostPosted: Wed Jan 23, 2013 1:11 am    Post subject: Reply with quote
Awesome.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
steve924
PostPosted: Wed Apr 10, 2013 11:13 pm    Post subject: Reply with quote
A little more, finding the time is a pain at the mo
3" exhaust downpipes
fitted
Almost there wiring, intercooler and piping up the cooling and fuel to go, I will tidy all the wiring etc once its done.
Porsche 924 na
porsche 924 1.8t
the_mad_electrician
PostPosted: Thu Apr 11, 2013 2:28 am    Post subject: Reply with quote
Still awesome.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
Brian L.
PostPosted: Thu Apr 11, 2013 2:08 pm    Post subject: 1.8 Reply with quote
Cool, glad to see this prodject is still moving forward. For anyone wondering why he would be putting a tiny little 1.8 motor in place of the stock 2.0, well I have one in my 2003 Passat and if you didn't know what engine was under the hood and after taking a test drive you would think it was a 2.5 because it pulls right away with zero turbo lag and with 5 valves per cylinder the rpm's just keep on climbing. Really an amazing engine! Keep up the good work!
1980 924 N.A. Monaco Blue owned since 1988
steve924
PostPosted: Thu Apr 11, 2013 7:24 pm    Post subject: Reply with quote
I love these little 1.8t's this one will only be a moderate tune of around the 300 bhp mark which is easy to acheive with these little motors (decent turbo etc once its up and running).
Porsche 924 na
porsche 924 1.8t
steve924
PostPosted: Sat Apr 20, 2013 11:44 pm    Post subject: Reply with quote
intercooler is in, moved the radiator back
engine bay starting to fill up, it will all be tidied up
Porsche 924 na
porsche 924 1.8t
PostPosted: Wed May 08, 2013 2:44 pm    Post subject: Reply with quote
quick question, whats the bore spacing on the 1.8t?
