In a real jamb here
Luvmy80-924
PostPosted: Wed Dec 05, 2012 12:13 pm    Post subject: In a real jamb here Reply with quote
My trans damper(477.521.603) started throwing chunks of rubber out the bottom of the torque tube. Does anybody have a source for these? Everywhere I look they are NLA. The 944 has a different part number, so I would imagine it wouldn't work? With it being this time of the year, just buying the 931 and the N/A being my daily driver, this is really killing me.
Any ideas? is there a way around it? install a clutch?
1980 924 N/A Everyday Driver
1986 930
And now a 1980 931
Mike924
PostPosted: Wed Dec 05, 2012 5:58 pm    Post subject: Reply with quote
So, it's an automatic transmission...?
Good luck with the clutch install!
1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org
Luvmy80-924
PostPosted: Wed Dec 05, 2012 8:36 pm    Post subject: Reply with quote
Yes, a clutch, if the damper breaks the torque tube will no longer turn, car goes no where. Can't find a damper, if a clutch (flywheel and plate, no need for a bearing or fork etc.) was instaled it would turn the torque tube and still dampen to a degree(springs on clutch plate). If there is reason this would't work coud someone please tell me.
I don't understand why the car even needs the damper. I'm just looking to get the car back on the road asap.
1986 930
And now a 1980 931
Mike924
PostPosted: Wed Dec 05, 2012 8:45 pm    Post subject: Reply with quote
Are you thinking of replacing the torque converter with a clutch or having a clutch in additon to the torque converter...? Or have I got that completely wrong?
Luvmy80-924
PostPosted: Wed Dec 05, 2012 9:00 pm    Post subject: Reply with quote
The torque converter is in the back of the torque tube, the clutch would be installed in the front just like a standard trans car. There would be no reason to have to disengage the clutch, it's just there to act like a damper and turn the torque tube.
This is just one idea I had. I REALLY need this car back on the road.
1986 930
And now a 1980 931
Mike924
PostPosted: Wed Dec 05, 2012 9:05 pm    Post subject: Reply with quote
OK, having looked at PET I think I see what you're trying to do.
Yes, in principle, what you are proposing will work.
In practice, the difficulty will be in finding the right parts that will fit in the space and will interface to the input and output shafts...
Tiny
PostPosted: Wed Dec 05, 2012 10:08 pm    Post subject: Reply with quote
I remember reading about a similar situation a while back.
Here's a thread which may help:
http://www.924board.org/viewtopic.php?t=25566&highlight=clutch+install+damper
*****1981 - 924 - Auto - London, UK******
Luvmy80-924
PostPosted: Thu Dec 06, 2012 1:14 am    Post subject: Reply with quote
Why does it need this damper? Can it be welded solid?
PostPosted: Thu Dec 06, 2012 2:17 am    Post subject: Reply with quote
Could you convert it to a manual?
emoore924
PostPosted: Thu Dec 06, 2012 4:06 am    Post subject: Reply with quote
There's a thread about this over on pelican right now. Someone is fixing their auto tranny 924, and the discussion centers around whether they should install an original part auto dampener or replace the dampener with an actual manual transmission clutch in place of the dampener (this is not changing to a manual tranny...)
Might be worth checking in there...
Luvmy80-924
PostPosted: Thu Dec 06, 2012 5:59 am    Post subject: Reply with quote
I would love to convert it to a manual, but I would need the parts for that also. Anybody have what I need for that?
1986 930
And now a 1980 931
PostPosted: Thu Dec 06, 2012 8:11 am    Post subject: Reply with quote
I would buy a donor car and use that.
http://philadelphia.craigslist.org/search/cta?query=Porsche+924&catAbb=pta&srchType=T&minAsk=&maxAsk=
http://philadelphia.craigslist.org/search/cta?query=Porsche+924&srchType=T&minAsk=&maxAsk=
Also check the local salvage yards for wrecked/junked cars you can pick over for parts. Carpart.com is a good source.
emoore924
PostPosted: Thu Dec 06, 2012 11:19 am    Post subject: Reply with quote
I think the idea is to use a rubber-centered clutch plate for a dampener instead of the actual auto-tranny dampener part. Much less expensive but retains the auto tranny for shifting.
Check the other thread....
Luvmy80-924
PostPosted: Thu Dec 06, 2012 8:57 pm    Post subject: Reply with quote
This is what I decided to do. I'm going to Advance Auto today and buying a 90 VW Jetta clutch and pressure plate. I'm told it will fit the 24 tooth auto torque tube; It is a 1/4 smaller than the normal N/A cluth but a lot cheaper and like I said it would never be disengaged. I should be able to getting to putting this in by the weekend I'll let you know how it turns out.
1986 930
And now a 1980 931
DOCO
PostPosted: Fri Dec 07, 2012 6:01 am    Post subject: Reply with quote
Before you go to all this work,check what the clamping force is on the vw clutch.Then find out the clamping force of the porsche clutch. If the vw is less you might end up with a slipping clutch if it cant hold the torque from your porsche.Just a thought
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
