Can you feel the blow?
If you remove the oil cap while your 924 is running, how much blow can you feel through the hole?
Absolutely no blow.
37%
 37%  [ 3 ]
Tiny amount of air coming through.
12%
 12%  [ 1 ]
Yes yes, there is definitely some blow. I find this poll awkward.
12%
 12%  [ 1 ]
Major blower.
0%
 0%  [ 0 ]
Look dude, my car is faster than yours!
37%
 37%  [ 3 ]
Total Votes : 8
9xx
PostPosted: Thu Nov 01, 2012 4:22 pm    Post subject: Can you feel the blow? Reply with quote
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
Ozzie
PostPosted: Fri Nov 02, 2012 12:07 pm    Post subject: Reply with quote
If anything there should be a mild vacuum here.
If it is blowing you probably have a blocked breather or worse
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Fri Nov 02, 2012 5:25 pm    Post subject: Reply with quote
There is some blow...not that much...but its there.
If you put the cap close to the hole it will suck it closed...so with the cap on there will be vacum.
9xx
PostPosted: Fri Nov 02, 2012 6:41 pm    Post subject: Reply with quote
Block breather was cleaned year ago and it is not blowing oil inside the air filter box. Similar to morghens experience, there is a slight blow when the oil filler cap is removed. Otherwise the engine is running very strong.
Mikko
Ozzie
PostPosted: Sat Nov 03, 2012 7:27 am    Post subject: Reply with quote
put a sheet of A4 paper near the hole. it should be sucked onto it.
+1 if so.
emoore924
PostPosted: Sat Nov 03, 2012 9:23 am    Post subject: Reply with quote
For you newbies out there, do NOT let go of the paper. Do NOT let it actually get sucked into the hole. That would be bad.
Just sayin.
