Rear susp from a vw?
Noahs944
PostPosted: Tue May 31, 2016 12:39 am    Post subject: Rear susp from a vw? Reply with quote
What is the rear suspension from? I know it says Porsche on it, but I've read it was used on VW rabbit or bug or something before. Is this also true about the cv/drive shafts? Off the top of your heads do you know the spline count and diameter of an early 924 n/a? Thank you!
PostPosted: Tue May 31, 2016 1:36 am    Post subject: Reply with quote
911
The vw beetle uses a similar system as well..but its not the same.
