Harm
Posted: Sun Jul 14, 2013 8:27 pm Post subject: DIY: CIS Test Kit aka Fuel Pressure Tester. |
Some POs have neglected the CIS system on the Toofah
by faulty diagnosis, or the complete lack thereof ,
and that's why/when they end up at Craigslist for a box of chocolates…
Getting and keeping your Toofah on the road means you'll have to check up the amount of fuel she's fed to make sure the CIS is fully functional and deviating valeus on one of its components can be dealt with in time. By either reading up here or going through the Haynes Manual you can make sure your Toofah gets that healthy dosis of fuel into its mixture by taking out the gremlins with a DIY Fuel Pressure Tester.
How does it work?
Simply collect all the parts (~eight) needed for a CIS Test Kit locally or order online and assamble them together safely at your kitchen table before going out testing.
Over at VdubVortex the guys build there own CIS Test Kit for less then $50 bugs on parts.
…It's pretty easy actually!
I bed you guys wanna look into that
http://forums.vwvortex.com/showthread.php?6060634-DIY-Fuel-Pressure-Tester&p=82272967&viewfull=1#post82272967
Apparently the biggest problem for members across the pond
is finding these metric fittings (12MM diameter with 1.5 thread)
but that problem will be tackled by nowadays online parts stores, suppliers & distributors…
Please share results, upgrades and observations.
Hope This Helps
Kind Regards,
Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Mon Jul 15, 2013 4:09 am Post subject: |
buy one from Ideola's garage? _________________ https://www.the924.com |
Harm
Posted: Mon Jul 15, 2013 8:12 am Post subject: Re: DIY: CIS Test Kit aka Fuel Pressure Tester. |
morghen wrote: | buy one from Ideola's garage? |
If one was unable to build a simple instrument as the Fuel Pressure Tester mentioned, he or she will
most likely have inadequate skills to work on the Contineus Injection System aka Bosch K-Jetronic.
Such a person would preferably leave the Toofah in the hands of a well trained mechanic.
…which subsequently deletes the need to acquire a Fuel Pressure Tester Kit.
btw ideola wrote: | I've stopped selling the Hoffman TU-14C test kits … |
Keep this topic DIY _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Mon Jul 15, 2013 4:46 pm Post subject: |
oops, sorry 'bout that you're right. _________________ https://www.the924.com |
JasonK
Posted: Mon May 05, 2014 6:16 am Post subject: |
Great link, which contains an even better link!
I'm trying to build this tool, I was not able to find it on Ideola's Site.
Clearly assembly is not an issue, the service at Autozone and Oreileys (or lack thereof) has needlessly cost me quite some time however. The $150 autozone tool did allow me to determine that my regulated pressure seems to be high, however I cannot test system pressure without a valve.
I got most of the parts from my local family owned hardware store, and would like to be able to discuss sources and part numbers for the metric fittings here if anyone else is interested. |
procyon
Joined: 09 Sep 2015 Posts: 70 Location: Peers Alberta Canada
Posted: Wed Sep 30, 2015 11:29 am Post subject: |
I am having problems finding the 12x1.5mm fittings. Mcmaster-Carr won't ship to Canada and even Swagelok doesn't have parts of that size listed.
Some part numbers would be great. _________________ 1981 924 N/A (Now the parts car)
1980 924 N/A ( 5 bolt discs and better paint) MS II V3.57
2003 Subaru Baja
2021 Maxda CX-30 |
Posted: Wed Sep 30, 2015 9:10 pm Post subject: |
Try Belmetric. They have an excellent selection of metric fittings, including banjo style eyelets and bolts. https://www.belmetric.com/ _________________ erstwhile owner of just about every 924 variant ever made |
procyon
Posted: Thu Oct 01, 2015 10:26 am Post subject: |
Thanks I'll give them a try. _________________ 1981 924 N/A (Now the parts car)
2003 Subaru Baja
2021 Maxda CX-30 |
Han Solo
Power Tryp
Joined: 16 Apr 2009 Posts: 434 Location: Calgary, Alberta
Posted: Wed Oct 07, 2015 4:34 am Post subject: |
You can also purchase a complete kit from http://www.specialtauto.com/ as Delorean's also used the k jet system. _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
