Dash Repair
Goto page Previous  1, 2
PostPosted: Mon Nov 03, 2014 5:56 am    Post subject: Reply with quote
My problem with using the mat rather than cloth is that I normally use epoxy(West System) and the mat surface treatment is made for using polyester based resin. For me polyester has always been a rather poor adhesive. Granted I normally work with epoxy in a more structural systems than the dash requires, but it is just my normal working material so I just don't think about it.
Mike
'77 924
cricketdesigns.com
sciroccosteve
PostPosted: Sun Aug 09, 2015 1:10 pm    Post subject: Reply with quote
curious how this has held up, thinking of doing the same to mine
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns
PostPosted: Fri Aug 21, 2015 1:45 am    Post subject: Reply with quote
Where I used the epoxy and fiberglass it has held up very well and the fiberglass is a fine enough weave that it doesn't show thru. I had one crack reopen in the face. If doing it again I'd cover the parts of the face that I could. Around the gages would get pretty dicey.
Since you're in NY what I would do is all the prep work with the filler which takes 90% of the time and then look up Brad Gillespie at Gillespie Paddles who is /or was in Rochester and see if he would do the glassing. He would have all the materials and epoxy and I could supply the glass if needed(its only about $5.00 worth). He does this stuff all the time. If you haven't used fiberglass and epoxy there is a short, but not penalty free learning curve.
Mike
'77 924
cricketdesigns.com
Lefty
PostPosted: Wed Sep 16, 2015 7:11 am    Post subject: Reply with quote
The results look great and I was wondering How is the dash holding up after 3 years
Cheers
Lefty
One less beige car
PostPosted: Sat Sep 19, 2015 12:02 am    Post subject: Reply with quote
Unfortunately some of the cracks which I did not fiberglass fave opened up again. The part that works best is where I basically reskinned it. Frankly, I think reskinning is the answer. I did all the more or less horizontal surfaces and ignored the front thinking it wuold get sloppy, I should have continued on with about 2" wide strips over all the vertical cracks. The bed spray on stuff I used covered the seams well enough so that they disappeared. Trying to glass around all the complex curves would get messy, and I have worked this stuff for many years.
I used type 2112 2oz fiberglass available from Sweet Composites(my supplier for the past 30 years), Fiberglast Developments(Expensive) of Fiberglass Supply and many others. I could send the necessary yard in a USPS mailer and It is only about $3 or $4 for the cloth. I used West Epoxy although any of the other thin boat building epoxies would work just as well. If they weren't so expensive to ship around I could do the fiberglassing. The filling takes more time than I care to spend.
Make no mistake, this is still a budget process and does not have nearly the same result as a proper and expensive recover.
If I left something out here sorry, Have a flat tire on the rented skidsteer and have to run off.
Mike
'77 924
cricketdesigns.com
Page 2 of 2
