stripped crossmember bolts
kpasko
PostPosted: Mon Sep 19, 2016 11:06 am    Post subject: stripped crossmember bolts Reply with quote
ok it's official. somehow or another, despite being, optimistically, generally-not-an-idiot, i managed to very-idiot my way to stripped front cross-member/chassis bolts.
no, i don't know how. and yes, those ones, the ones welded into their own welded boxes themselves welded onto the frame.
for better or worse (read: worse) in my frustrated-as-hell state, I impact-drove the nuts off, stripping the threads with the thought/hope that I could maybe retap at a smaller diam and get something on there secure enough to at least get it to a shop and so forth.
not sure what to do at this point, as it's a '78 924...could mayyyyybe sell for 2k on a good day, with bolts intact...at this point is she doomed for the dump? do i have any recourse at this point that isn't annoying as hell?
also: watch this space for potential parting out soon accordingly.
*sigh*
PostPosted: Mon Sep 19, 2016 11:33 am    Post subject: Reply with quote
I stripped a trans mounting point and there was enough material to go over size larger and retap. Also, Dan has used rivnuts for a moderately loaded application in the same area without problems.
  • Wei�e (1987 924S) - 931 S3
kpasko
PostPosted: Mon Sep 19, 2016 11:48 am    Post subject: Reply with quote
thanks rasta. no threads left on them, down to center bolt diam, as my more patient and delicate efforts didn't make any progress either tightening or loosening.
rivnuts may work...do you think they'd be strong enough for the four front crossmember mounts?
PostPosted: Mon Sep 19, 2016 3:21 pm    Post subject: Reply with quote
I think some rivnuts are quite beefy depending on material, and those bolts I don't think are that tight.
Having said that, I'd wllalso think it should be fairly easy to cut that section from a parts car and weld it into yours.
