Make your own exhaust hangers
!tom
PostPosted: Mon May 14, 2012 6:01 pm    Post subject: Make your own exhaust hangers Reply with quote
Well, this is making just the part that attaches to the exhaust so you can keep using the rest of the OE hangers.
As usual, click for bigger pics.
  1. Get all the stuff you need. You need a muffler clamp to fit your exhaust, and get new U-bolts for your exhaust hangers too; those are the U-bolts that go around the torque tube.
  2. Cut the strap that came with your U-bolt in half. You're going to attach the pieces to the exhaust clamp.
  3. Center up your straps with your OE hanger, and measure to ensure you're going to get your exhaust at the right height. Attach with bolts to ensure the alignment is correct.
  4. Weld 'er up. This is what it should look like when you're done.
Some tips:
  • Put the flat side of the OE hanger against your homemade piece, along with a washer.
  • The reason for using the U-bolt straps is they have slots for exhaust adjustment.
  • Put your bolt head next to the U-bolt part of the muffler clamp.
  • The pictures shown aren't in the orientation that they'll be installed on the car. See above tips.
Edit: Fixed URL's
78 924 NA
5-lug
deborah5123
PostPosted: Wed Aug 13, 2014 3:28 pm    Post subject: Re:Make your own exhaust hangers Reply with quote
Well, thanks for this one. I am not good in doing car stuff.
PostPosted: Thu Aug 14, 2014 10:18 am    Post subject: Reply with quote
I cant see the pics, can anyone else?
!tom
PostPosted: Wed Aug 20, 2014 1:27 am    Post subject: Reply with quote
Nope, but you should be able to now.
78 924 NA
5-lug
PostPosted: Sun Aug 24, 2014 2:14 pm    Post subject: Reply with quote
Thanks... Mines been to low for too long as maybe you've noticed. You've made it easy for me to raise it up.
