Timing belt cover: To replace, or not to replace?
bureau13
PostPosted: Wed Jan 03, 2018 12:22 am    Post subject: Timing belt cover: To replace, or not to replace? Reply with quote
So how many of you replaced your timing belt cover? This thing is annoying. I know of at least one car that was purchased (used) with no timing belt cover, so a PO at least did not replace that one (assuming they all came with them). I thought I read once that someone in the 928 world didn't replace theirs and noticed increased belt wear, but I could be remembering that wrong.
(I'm assuming for the sake of argument that I'm able to eventually get it off without going mad and cutting it off or something)
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
PostPosted: Wed Jan 03, 2018 1:03 am    Post subject: Reply with quote
Both my cars have no cover.
I don't drive in extreme conditions and that's working fine for me.
The belt is cheap and i replace them every other year.
bureau13
PostPosted: Wed Jan 03, 2018 2:21 am    Post subject: Reply with quote
That sounds good to me...just need to get the thing off now!
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Wed Jan 03, 2018 3:52 am    Post subject: Reply with quote
careful not to damage/cut the timing belt while you're taking the cover off.
Cédric
PostPosted: Wed Jan 03, 2018 3:54 am    Post subject: Reply with quote
The engine looks nicer with a nice painted cover imo. I trimmed it a little bit and now it's super easy to take of.
´80 924 Turbo
PostPosted: Wed Jan 03, 2018 5:30 am    Post subject: Reply with quote
I have cut the lower part of, it is now very easy to install
Just one extra bracket with a rubber to keep it steady.
937 DITC
bureau13
PostPosted: Wed Jan 03, 2018 5:44 am    Post subject: Reply with quote
I'm kinda liking this idea of trimming the cover so it fits easily...
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
GeneT95
PostPosted: Wed Dec 04, 2019 9:00 am    Post subject: Reply with quote
I drilled out the spot welds holding the the lower flange section and removed it. Much easier to deal with, but to be honest, I've yet to replace it as I wanted to recheck belt tension after a water pump replacement.
61 Biscayne : 62 Bug : 81 931 : 88 944 NA
PostPosted: Wed Dec 04, 2019 9:21 am    Post subject: Reply with quote
I like the look seeing the cam wheel spinning.. Different strokes..
I also grab and inspect my timing belt like every time I open my hood, and before I close my hood I almost always check very well that I haven't left anything in there that can get caught in the timing belt..
I think the 928 belt cover is more of like a sealed belt compartment type thing that keeps the belts perfectly clean, no?
The 931 cover is more of a, don't get your fingers or large foreign objects in there, sort of thing, I think..
kondzi
PostPosted: Thu Dec 05, 2019 3:42 am    Post subject: Reply with quote
Forgot to install mine, took it in hand, watched closely what I need to do to install it... put it on shelf. I’m not missing it at all. And me as well - I like to see the timing wheel spinning.
Konrad
'89 951 US
'81 931 RoW (TBD)
bureau13
PostPosted: Tue Dec 17, 2019 4:02 am    Post subject: Reply with quote
You are correct, the 928 cover is in three parts and covers the belt and various rotating bits completely.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
K-Roll931
PostPosted: Sat Apr 11, 2020 12:01 pm    Post subject: Reply with quote
I've had mine on for the last year. Less clutter in the garage for me, and it looks cool! I can still see the timing marks if needed.
'80 931 M471 - Dolomite Gray -> Monaco Blue
jacobroufa
PostPosted: Sun Apr 12, 2020 8:22 am    Post subject: Reply with quote
Funny, I've been debating on whether or not to put it back on before I wrap up this maintenance! Still can't decide!!
Update: installed it today.
1980 Porsche 931
1981 Porsche 924 Weissach
jacobroufa
PostPosted: Mon Apr 20, 2020 12:24 am    Post subject: Reply with quote
I'm regretting week-ago-me's decision to do this, after last night's debacle with the leaking water pump... I'll probably still put it back after it's all said and done anyhow!
1980 Porsche 931
jacobroufa
PostPosted: Mon Apr 20, 2020 12:26 am    Post subject: Reply with quote
1980 Porsche 931
