itbracer85porky
Joined: 02 Mar 2012 Posts: 43 Location: New Hampshire
Posted: Thu Apr 12, 2012 11:16 am Post subject: early 924 headlight question |
Hello all. I am working on my 1977 D production replica. When I turn on just the parking lights, the headlights pop up, but are not on in the middle switch position. All the lights work just like on my 944, but I dont think the headlights should pop up in the middle switch position. Is this correct? If there is a fault, any thoughts on where it could be? Bad switch or relay? _________________ 1977 Porsche 924 DP Replica (in process)
1984 Porsche 944 Euro conversion
1990 Eagle Talon SCCA ITA
2010 Ford F150 Supercrew
2012 Nissan 370 sport pack |
Posted: Thu Apr 12, 2012 11:46 am Post subject: |
I believe the relay is just a standard relay same as used for several other components, so you should be able to pop out the A/C or radio relay and swap it in to test (the one on the motor). The relay from your 944 should work too. The buckets should not lift when the running lights are on, and there should be no current going to the headlight motor in that position, so it is more likely to be a fault in the switch, as those things do go bad (and can cause melted wires!), but I would see about eliminating the relay as a variable first... _________________ erstwhile owner of just about every 924 variant ever made |
itbracer85porky
Posted: Thu Apr 12, 2012 11:59 am Post subject: |
Wow, that would be great. There are two early 924's at the scrapyard right up the street from me that I could get a replacement switch to try. I just went through a ton of headlight trouble with my recently restored 944. I had no driver side high beam, and it did indeed melt some wires at the switch, and killed the switch too!
Thanks a million for the info. I will give it a try. _________________ 1977 Porsche 924 DP Replica (in process)
!tom
Joined: 28 Aug 2006 Posts: 1934 Location: Victoria, BC Canada
Posted: Thu Apr 12, 2012 3:47 pm Post subject: Re: early 924 headlight question |
itbracer85porky wrote: | Hello all. I am working on my 1977 D production replica. When I turn on just the parking lights, the headlights pop up, but are not on in the middle switch position. |
That's how it works on my '78. _________________ 78 924 NA
5-lug |
Joined: 29 Jul 2001 Posts: 8811 Location: Royal Oak, MI, USA
Posted: Thu Apr 12, 2012 9:46 pm Post subject: |
Agreed, that sounds correct for the early cars... but could be adjusted, IIRC, by rewiring or replacing the headlight switch with a later one. I think. _________________ Vaughan Scott
itbracer85porky
Posted: Thu Apr 26, 2012 10:53 am Post subject: |
Well, I have replaced both the relay and the switch with brand new ones, and I still have the same problem (headlight popping up on the driving light setting). Any other ideas out there? Could it be something shorting out in the motor itself? Thoughts? _________________ 1977 Porsche 924 DP Replica (in process)
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Thu Apr 26, 2012 12:11 pm Post subject: |
I believe the actuator disk on the lifting motor and its associated wiring is different in the earliest cars. The Haynes diagram is different, I do know that. I daresay replacing or rewiring that will likely be required to alter its behaviour.
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
vatoisimo
Posted: Tue Dec 17, 2013 8:43 am Post subject: |
did you ever figure out what the problem was. I am having the same issue...
Jim |
larchie
Posted: Tue Dec 17, 2013 12:02 pm Post subject: |
Different models of 924 and 944 operate a little differently as discussed in part on the Pelican Board. If you read circuit diagrams,, Clark's Garage has some good troubleshooting tips in the Headlight Motor Circuit - Operation and Repair which, with your model's wiring diagram, can be straightforwardly adapted. Generally, the problem of the headlights raising in the first position is solved by a new switch as ideola states above. If you have an early 924, normal operation includes this odd behavior: after the headlights are raised and on in the second position of the switch, and then when switching back to the first position, the lights go off and but headlamps remain raised. |
vatoisimo
Posted: Tue Dec 17, 2013 1:48 pm Post subject: |
I think I understand that a bit better, and I will check the relay tomorrow. That being said, the issue I am having is that the headlights pop up when I hook up the battery, and it doesn't matter what I do with the switch, they stay up. Or If I hook up the linkage opposite, they will not come up..........??? I have 3 wires and the plug in has a jumper that feeds off of the grey wire. this matches the current flow diagram in the Haynes manual. the red always has power, and when you flip the switch the gray and red have power. hmm maybe it is the relay.....yep will check that tomorrow. Thanks!
Jim |
scm924s
Joined: 22 Oct 2010 Posts: 268 Location: Gloucester UK
Posted: Tue Dec 17, 2013 8:27 pm Post subject: |
On the euro spec early car, the operation you describe is correct, the lights pop up on switch position 1 but only the lower sidelights operate, position 2 brings in main beam. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
brian19600
Posted: Thu Dec 19, 2013 3:41 am Post subject: headlight |
From page 16 of the 1978 Porsche 924 owners manual:
"Tail lights, sidemarker lights, license plate and instrument lights are on in both switch positions.
The retractable headlamps open when depressing the switch to the first stop." _________________ 78 924 |
vatoisimo
Posted: Thu Dec 19, 2013 12:20 pm Post subject: |
OK! wiring to motor Relay: replaced, not the problem Motor: study the wiring diagram and fiddle with the motor. jump power to every connection and I discovered: A BAD DIODE! So, $1 diode, a little cutting/soldering and WHAM! lights go up and down! thank you everyone for all the info and links!
Cheers
Jim |
larchie
Posted: Thu Dec 19, 2013 1:45 pm Post subject: |
Amazing! I never would have guessed! Thanks for posting back to the board; I was curious what you would come up with -- having found the solution to a similar problem in a 924 a few years ago being the contacts in the motor assembly. |
vatoisimo
Posted: Thu Dec 19, 2013 3:05 pm Post subject: |
Luckily I have 2 motors. so I cut the rubber boot off of the rougher looking one. right under the relay, and the plug in; are 2 diodes as shown in the Haynes electrical diagram. On both motors they were bad. Meaning that they would allow current to return back to the circuit. or in the case of the good motor, would not flow any current. On the cleaner motor I cut a circular hole in the boot which allowed me to do my surgery. Now I just need to figure out how to seal it back up. was thinking of using some shrink wrap. Maybe the same stuff they use to seal boats up for the winter....what do you guys think? |
