tuf-924
Posted: Wed Feb 08, 2012 8:06 pm Post subject: Gear lever feels loose?????? |
Hey guys I have an Australian model 924, The gear lever is really loose when going left and right there is heeps of play in gears also moving lever right to left has lots of play, is there any bushes that can be replaced? And are they easy to get to? _________________ Vass... |
Posted: Thu Feb 09, 2012 5:21 am Post subject: |
Yes, there are bushings (and other parts) to replace for both styles.
If you have the Porsche box (dogleg first gear) then the bushings are likely the primary issue, specifically the bushings under the car above and in front of the transaxle. There are bushings at the shifter as well that should be replaced. I think they are similar to Porsche 924 bits. Otherwise the screw that holds the linkage to the front of the transaxle might have worked loose.
If you have the Audi box (non-dogleg first) then the shift lever might be worn out, the linkage may have come loose in the rear or you could have bad bushings. This is a common problem with the 944 and 924S, so lots of solutions are documented online as well as parts available to purchase.
Hope this helps. _________________ Stefan
tuf-924
Posted: Thu Feb 09, 2012 6:10 am Post subject: |
Ye this does help, are they hard to replace?? Or just to get to cause there isn't much room to get your hands above the transaxle? Also it's an 82 model with the 5 speed manual box _________________ Vass... |
Posted: Thu Feb 09, 2012 7:02 am Post subject: |
Look under it right away and find the conical bolt that connects the shift rod to the gear selector shaft entering the gearbox. It should be tight and safety wired. _________________ Toofah King Bad
