okkie
Posted: Thu Dec 01, 2011 1:40 am Post subject: Main bearings |
| Ok guys, now that there is no OS bearings available for the 924, is the only alternative to source a crank with Standard journals? Can a crank be welded and machined to Standard size or what can be done. I read the posts in a previous discussion with interest, but it died down with no real result. |
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Thu Dec 01, 2011 8:41 am Post subject: |
In the old days hard chroming and grinding cranks to bring them back to standard was common place. Havn't heard of it been done latley though.
If someone (i.e. ideola!) wanted to do another group buy, I would be up for a couple of sets of OS bearings
Cheers
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Julian
Posted: Fri Dec 02, 2011 1:22 am Post subject: |
| They can be welded and turned back down, but it gets expensive to have it done. Usually done to a single damaged journal to save a crank. |
Martijnus
Posted: Fri Dec 02, 2011 4:09 am Post subject: |
I don't see why king doesn't produce them. They have done it before and there sure is some market for it. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
