SHES ALIVE :).
tuf-924
PostPosted: Thu Dec 01, 2011 9:35 pm    Post subject: SHES ALIVE :). Reply with quote
Got my car back up and running all tuned up and running like a dream.
Just noticed my speedo is like 8km's off, just wondering if these cars have a speed sensor somewhere? I could not find it on my w/s manual need abut of help here.
Also I'm in need of drivers and passenger window rubbers inner and outer any ideas where to get some in australia?
Vass...
924aussie
PostPosted: Thu Dec 01, 2011 9:40 pm    Post subject: Reply with quote
Porsche Brisbane carries them if you cant find any
Alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1998 Nissan Silvia ... sons back from OS he has taken it
BIG BLOODY MOTORHOME 300zx Sold
1980 Fire truck Sold
Ozzie
PostPosted: Fri Dec 02, 2011 9:28 am    Post subject: Reply with quote
speedo is run via cable off the LH front wheel.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Fri Dec 02, 2011 3:00 pm    Post subject: Reply with quote
Speak to Dennis at aporschaparts mordialloc,
Congrats too on getting the car going
tuf-924
PostPosted: Fri Dec 02, 2011 11:09 pm    Post subject: Reply with quote
Cheers thanks, Ye took a while to get the fuel pressure right then the timing and still wasn't running well but it started got it tuned at the local Volvo mechanic he got it running so good. Now my alternator belt is slipping putting a new one on tomorrow also got my reg replaced in my alternator and it's charging at 13.5 volts, I think it might have leaking diods because it jumps from 13.5 to 14.5 on the multimeter every now and then
Vass...
emoore924
PostPosted: Sat Dec 03, 2011 4:06 am    Post subject: Reply with quote
Might need an alternator bushing mount replacment kit.
Look at the alt pulley and see whether it is running flush/in parallel with the front of the motor. If the bushings have perished (ooohh, learned "perished" from Wheeler Dealers ) you'll need to replace the mount bushings so the pulley, and hence the belt, run in line with the cam pulley and the alt therefore is properly driven...
Might also explain the slight variability in the voltage, although that sounds in-range to me...
SilverGhost
PostPosted: Sat Dec 03, 2011 12:10 pm    Post subject: Reply with quote
... but also get a price from Porsche Centre Melbourne, as they are cheaper for some parts. One part I needed was cheaper new from Porsche than secondhand from aporschapart.
"Priscilla" 1981 924 NA RoW auto, metallic blue
tuf-924
PostPosted: Sat Dec 03, 2011 1:33 pm    Post subject: Reply with quote
Yea ma mate has a 944 and today he said the same thing about Porsche centre melba, might compare prices ay.
Now that you mention it emoore924 it does look like it isn't spinning correctly, also noticed 2 fins have been snapped off the pulley.
Vass...
