Johntom
Joined: 30 Aug 2011 Posts: 18 Location: South Yorkshire
Posted: Thu Nov 03, 2011 7:16 am Post subject: turbo priming |
Hi
I have just finished replacing the turbo on my 1981 S2, (along with the cam belt and oil change etc, etc).
How do i prime the turbo with oil?
The haynes manual says 'remove the plugs from the manifold pressure switch', where is this located as the manual doesn't tell you ? |
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Fri Nov 04, 2011 11:07 am Post subject: |
I think they are referring to the boost switch on the upper pressure duct. That way you can crank the engine without it firing. Also remove plugs.
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
nwns
Joined: 27 Sep 2008 Posts: 93 Location: Lancashire, UK
Posted: Fri Nov 04, 2011 9:28 pm Post subject: |
I just took the spark plugs out and cranked - it takes ages to get the pressure up in a fresh build. I thought it was going to burn out the starter. _________________ Pete |
Johntom
Posted: Sun Nov 06, 2011 6:23 am Post subject: |
Hi
thanks for the replies. I removed the plugs etc and cranked a 3 or 4 times for a number of seconds until the oil pressure moved up to 4 bar ish. The car started ok and no obvious blue smoke (although i didn't drive the car). Just got to sort the vibration which can be felt through the car at tickover , engine mounts, any ideas ? |
