Turning key,ignition on -No start
Nobbi
PostPosted: Fri Mar 16, 2012 3:02 am    Post subject: Turning key,ignition on -No start Reply with quote
Hi everyone,
in my 4/77 euro N/A i have a small problem.Yesterday i turned the key,fuel pump and all lights in the dash went on as usual but the car / starter motor didnt kick in.......Is that the white piece of plastic in the ignition lock failure or something else?
Input required..Thanks in advance
Nobbi
NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967
tyfighter123
PostPosted: Fri Mar 16, 2012 3:06 am    Post subject: Reply with quote
Sounds like the ignition switch. It is indeed that white piece of plastic. It should be a cheap fix!
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
Ozzie
PostPosted: Fri Mar 16, 2012 7:37 am    Post subject: Reply with quote
It could any of three things.
The ignition switch.
the wiring to the solenoid on the starter
the solenoid itself could be jammed.
all are common problems.
Its AUTO and its BLACK
Montego Black on black/red
joejax
PostPosted: Fri Mar 16, 2012 7:41 am    Post subject: Reply with quote
Weak bat-tree?
I got nothin'
Uhhh...you got any pics?
Nobbi
PostPosted: Sun Mar 18, 2012 6:24 pm    Post subject: Reply with quote
Problem solved,
it was one of the connectors inside the cable plug that leeds down to the starter.It came loose and i pushed it backinto position,car starts fine again.
Thank you all,
nobbi
