Posted: Sat Oct 27, 2007 3:25 am Post subject: Cooling Fan Rehab |
Anyone ever attempted to take apart their engine cooling fans to refresh the innards? I don't know much about electric motors, but it seems like there ought to be bushings or something in there that take the wear. . .but are they replaceable?
Discuss!
rasta _________________ Toofah King Bad
-nick
Posted: Sat Oct 27, 2007 4:07 am Post subject: |
I'm curious too. My main fan sometimes squeaks like a hampster wheel going 100mph during the short after-shut-down cycle. _________________ 1980 931S
1991 964 C4 Cabriolet |
!tom
Posted: Sat Oct 27, 2007 4:25 am Post subject: |
I re-bulit the melted mess that was the fan for the cabin air.
Usually bushings don't really wear out -- they tend to get all gross, and respond well to cleaning and a bit of oil.
I'm not saying bushings can't wear out, because they certainly can, but they often are pretty durable.
Brushes can also squeak, and there isn't much you can do about that. Cleaning them and removing the glaze that can form may eliminate brush squeak.
If it was built in the first place, then it can be disassembled and re-built. The problem then gets down to tools, skill, persistance, and ability to improvise when parts aren't avaiable.
The bushings in my fan motor were strange -- they were spherical on the outside, if I remember correctly. I ended up breaking one in half accidently -- they weren't very durable, but there's enough of it left to continue to do the job. There's no reason for me to believe the radiator fan motor is similar or very different than the cabin fan motor.
The fan motor was not intended to be rebuildable -- I had to grind off crimps, and bend tabs, and do a bunch of things like that which aren't intended to be taken apart. As I said though, persistance can get you results other techniques can't. _________________ 78 924 NA
5-lug |
Posted: Sat Oct 27, 2007 5:27 am Post subject: |
The rad fans can be disassembled with difficulty if necessary even though they're not designed to be. Sometimes lubing is all that's needed, so try that first. -But if there's any wobble to the front shaft and blades, you'll probably have to try a disassembly to deal with the bushings. Look here - http://www.924board.org/viewtopic.php?t=13861 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Ozzie
Posted: Sat Oct 27, 2007 8:15 am Post subject: |
I pulled mine apart after it failed. It appeard to have bushes not bearings which had disintegrated.
Tossed it in the bin.
Replaced it with a generic unit the same diameter from the auto shop.
1/4 the cost of genuine. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Sat Oct 27, 2007 9:55 am Post subject: |
Had this problem with mine a few years ago. Went from squeaking to vibrations and then the fan hitting the shroud. POS motor wasnt worth repairing IMO. Had a good look at the motor on my camry, fan was the same size, so in an saturday arvo mood of rather be driving the porsche than the camry, made an aluminium adapter plate and swapped them over.
Worked well ever since, much quieter for more air flow, no vibrations. These camry fans have proven their reliability and are widely available. Got another for the camry for $25 at the first wrecker.
Roger |
endwrench
Posted: Sat Oct 27, 2007 3:54 pm Post subject: |
Nice fix Roger! The OE Porsche fan fit the Toyota motor OK?
Posted: Sun Oct 28, 2007 1:35 am Post subject: |
Methinks thats the Toyo fan. _________________ Toofah King Bad
Posted: Mon Oct 29, 2007 7:25 am Post subject: |
Yea, thats the Toyo fan.
Perfect fit, lighter, stronger, better design, integrated aluminium boss, balanced.
Roger |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Mon Nov 14, 2011 10:37 am Post subject: Bringing back the dead |
Sorry for dragging this back up but what year camry is the fan from? I need a cheap replacement for my main rad fan.
Kevin
| RC wrote: | Had this problem with mine a few years ago. Went from squeaking to vibrations and then the fan hitting the shroud. POS motor wasnt worth repairing IMO. Had a good look at the motor on my camry, fan was the same size, so in an saturday arvo mood of rather be driving the porsche than the camry, made an aluminium adapter plate and swapped them over.
Roger |
_________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
Posted: Mon Nov 14, 2011 8:11 pm Post subject: |
SV21, early 90`s 4 cyl. _________________ World`s quickest 924 2L slushbox
| Allan @ DTA wrote: | | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
kcoyle
Posted: Mon Nov 14, 2011 10:28 pm Post subject: |
thanks! _________________ 1982 931- Stock with MBC at 8psi
