Rear Fuel line Rebuild
agfisher
PostPosted: Wed Aug 10, 2016 7:07 am    Post subject: Rear Fuel line Rebuild Reply with quote
Not super technical but I thought I would document the process I'm taking to rebuild the rear fuel lines in my 77 924. I while edit this first post as I add more information.
Here's my plan of attack for the rebuild.
1] Measure the lengths of all the hoses before damaging.
2] Break the assembly down into individual pieces and cut collars off of hoses.
3] Measure inner and outer diameter of hose for size verification and order appropriate fuel injection hose. Exacting to order around 3/8". Something like this http://www.speedwaymotors.com/Black-Push-On-Hose-6-AN,8976.html.
Looking at this stuff. Read quite a few good reviews about it. http://www.oreillyauto.com/site/c/detail/GATY/27340/N0887.oap
4] Clean up all fittings in my tumbler.
5] Electroplate fittings to protect.
6] Reassemble with new hose and fuel injection hose clamps. Like this http://www.jegs.com/i/JEGS+Performance+Products/555/16047/10002/-1
7] Install back into car.
Step One
The assembly has been removed from the car and is currently being soaked with Kroil to loosen fittings up. I took a picture of it's current set up and took measurements of all the hoses. The picture included below details these measurements for reference.
Step Two
I was able to break down the individual pieces without anything breaking or getting damaged. Here are a couple of photos showing how I cut the collars off.
I used a heavy-duty cut-off wheel on a Dremel to cut the collar. When cutting be careful not to hit the fitting on the end and damage it. Just cut the collar.
I found out you don't have to cut it all the way. Cut it most of the way and the fitting will just pull out.
I measured the inside diameter of the hoses used and it looks like they are 7mm ID (13mm OD).
Once the hoses were clear of the fittings I did some more careful measurements of the lengths. Here are the updated lengths.
A = 11 1/8"
B = 4 3/8"
C = 5 1/2"
D = 7 3/4"
Step Three
This is the replacement line I'm looking at right now https://www.amazon.com/dp/B0058XDL0K/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=GOPLIP3P93XG&coliid=I1LCONSUIWSB6H
Step Four
Here are some before and after pictures of some parts I ran through my tumbler. This is the first time I used it so I'm still getting the hang of it. I'm wondering if I should pick up one of those ultrasonic cleaners that Dan was talking about (http://www.924board.org/viewtopic.php?t=41990&highlight=ultrasonic) for getting the pieces super clean before plating.
Before:
After:
Here are some photos of the fuel system pieces before.
And after...
Here are some shots of some before and afters using the Ultrasonic Cleaner with the WD-40 Rust Removal Soak.
As of right now I'm really liking how the Ultrasonic Cleaner is working. It seems to do just a good a job but is much quicker. I'll try it some more and post some more pictures.
Here are some pictures of the fully cleaned hardware, before and after.
and the fuel system pieces
My verdict on the tumbler vs. the ultrasonic cleaner with the rust remover is the ultrasonic. Man, it really cleans well. The one problem is, in my experience, that you can't put too many pieces at once and the WD-40 Rust Remover solution is expensive (compared to how long it lasts). I want to try some of the homemade rust removing solutions (White Vinegar and salt, etc.) to see if they work just as well.
Step 5
OK, I got the plating down and here is a picture of the final pieces.
To Be Continued...
1977 924 N/A Martini Edition
brian19600
PostPosted: Mon Aug 15, 2016 3:16 am    Post subject: Reply with quote
Are the crimp tools expensive to do it like the factory?
agfisher
PostPosted: Mon Aug 15, 2016 3:30 am    Post subject: Reply with quote
I'm assuming yes so I never really looked into it. The ones I've seen at hydraulic are big. A hydraulic shop should be able to crimp a new one on for you but I wanted to find a solution I can do myself and modify if needed. With the fuel injection clamps I should be able to modify it to a 40cc accumulator system pretty easily if needed
PostPosted: Mon Aug 15, 2016 9:33 am    Post subject: Reply with quote
I think that if you just take that fuel line assembly right to a hydraulic hose shop, they can uncrimp your original fittings, replace the rubber lines, and then just recrimp your fittings..
1980 931S LSD FMIC hobby - 01 RS25 coupe - 95 M3 coupe - 06 X5
agfisher
PostPosted: Mon Aug 15, 2016 10:21 am    Post subject: Reply with quote
Your can but for me that would be crimping a new hose on really rusty fittings so if I went that way I would take them apart at home, clean them up, finish them and then get them recrimped at a hydraulic shop.
brian19600
PostPosted: Sat Sep 10, 2016 3:55 am    Post subject: Reply with quote
In reference to the fuel hose on Amazon:
I'm thinking that it is not 15 feet but 15".
agfisher
PostPosted: Sat Sep 10, 2016 4:48 am    Post subject: Reply with quote
It might be. I was just referencing the product type. My FLAPS carries the same stuff so I'll most likely get what I need there.
macBdog
PostPosted: Sat Sep 10, 2016 9:58 am    Post subject: Reply with quote
Love your method! Doing it RIGHT.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
PostPosted: Sat Sep 10, 2016 11:01 pm    Post subject: Reply with quote
Very cool writeup, will be following to see where this goes.
One word of warning: the CIS system operates at much higher pressure (more than double) normal EFI systems. I'm not comfortable that those fuel injection clamps are sufficient. At minimum, I would double clamp the fittings. Also, make sure the fuel hose you select is rated for at least 120 PSI.
Another suggestion: Harbor Freight carries an inexpensive ultrasonic jewelry cleaner. I've been using that on the heat cycle with WD40 rust remover soak, and it works wonders on almost everything I've attempted so far. It's faster and more effective than the tumbler, and I think will do a much better job preparing your end pieces for re-plating (suggest yellow cad dichromate). Do not use any other rust remover, as the other products I tried left a really sticky residue that required recleaning. The WD40 product is the best so far.
agfisher
PostPosted: Tue Sep 13, 2016 2:39 am    Post subject: Reply with quote
This is the plating system I'm thinking of using. http://www.eastwood.com/eastwood-s-tin-zinc-electroplating-system.html
According to Eastwood it is safe for fuel contact. Any opinions on it?
agfisher
PostPosted: Mon Oct 03, 2016 7:35 am    Post subject: Reply with quote
Updated first post...
brian19600
PostPosted: Wed Oct 19, 2016 7:45 am    Post subject: Reply with quote
One of the members has some 20cc accumulators in the for sale section.
brian19600
PostPosted: Wed Oct 19, 2016 2:53 pm    Post subject: Reply with quote
On a side note, the 477209241A is no longer available. So it is either the 477209241 from Griffiths, or rebuild it like yours.
agfisher
PostPosted: Fri Nov 18, 2016 5:54 am    Post subject: Reply with quote
Couple of updates. Rebuilding the harness in the next couple of days.
ozone
PostPosted: Wed Jan 04, 2017 5:43 am    Post subject: Reply with quote
Something to consider: the threads on the accumulators are -6 sized, JIC fittings.
AN fittings will thread on, but will not work/seal.
Side note: did you find the restrictor in the first accumulator line?
Post new topic   Reply to topic    924Board.org Forum Index -> How-To All times are GMT + 11 Hours
