mass air flow sensor?
Dean924s
PostPosted: Thu Jul 04, 2002 7:27 am    Post subject: Reply with quote
Does anyone out there know how to test the mass air flow sensor or any ideas of what is wrong with my 924s. my car will die out so that it is barely running sometime. you can't get the rpm above 2000. also when drive around 3000 rpms the car does a violent jerking. does at othe rpms but the worst at 3000. if you can help please do.
gohim
PostPosted: Thu Jul 04, 2002 7:42 am    Post subject: Reply with quote
You could try replacing the DME Relay, but the problem is probably a defective crankshaft ignition or positioning sensor.
You should check the clearances on the sensors.
