Nissebus
Joined: 07 Jun 2011 Posts: 20 Location: Gothenburg, Sweden
Posted: Mon Aug 08, 2011 6:57 am Post subject: Problems with my headlight! |
Hi again!
Now I'm having problems with my left headlight and I'm hoping that you guys and girls can help me.
The problem is that the high beam on the left headlight is'nt working. The low beam works though. The low beam and high beam works on the rest of the lights.
I've checked the connections to the lamps, no corrosion. I've checked the relay, I can feel and hear the click. Also, the relay was only there to prevent the electricity from dropping when the headligh turns on. I've tried the lamp in another car and it works just fine.
What could I've missed?
Thanks in advance! _________________ 924 -81 "The Frogmobile"
”Before you criticize someone, try walking a mile in their shoes. That way, when you do criticize them, you’re a mile away AND YOU HAVE THEIR SHOES!” |
Ozzie
Posted: Mon Aug 08, 2011 8:01 am Post subject: |
is there power at the light fitting?
probably a broken wire.
Fuses 1,2,3,4 do the headlights. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Nissebus
Posted: Mon Aug 08, 2011 3:01 pm Post subject: |
Hi Ozzie
I thought that there was power at the light fitting because the lamp lit up at the low beam. Do you think that there is a separate cable for the high beam?... Nah, it couldn't be because there is only tree wires; brown (earth), Yellow (minus?) and white (plus?).
I've checked the fuses a couple of times. They are whole and I can't seem to find too much corrosion. Perhaps I'm not looking hard enought.^^
...It's all still a mystery too me. :S _________________ 924 -81 "The Frogmobile"
Ozzie
Posted: Mon Aug 08, 2011 8:46 pm Post subject: |
There is brown earth, yellow low and white high. _________________ Porsche 924 1984 (UK import) NA
Nissebus
Posted: Wed Aug 10, 2011 7:12 pm Post subject: |
Aha! I'll check on the white cable right away then  _________________ 924 -81 "The Frogmobile"
Nissebus
Posted: Thu Aug 11, 2011 12:17 am Post subject: |
I checked the white cable but it seems that it doesn't have any power. Tried the yellow cable connected to the white one that leads to the light and then I got a high beam on the left and a low beam on the right. I think that the cupling at he back of the the fusebox might be corroded. It's like snakepit in there though.
Just have to gather myself to deal with it.  _________________ 924 -81 "The Frogmobile"
Ozzie
Posted: Thu Aug 11, 2011 8:30 pm Post subject: |
sometimes just cleaning the fuses and the holders works. _________________ Porsche 924 1984 (UK import) NA
Nissebus
Posted: Fri Aug 12, 2011 12:47 am Post subject: |
I've done that a couple of times already. It has helped a bit with other electrical functions but not this one unfortunately. _________________ 924 -81 "The Frogmobile"
Ozzie
Posted: Fri Aug 12, 2011 7:36 am Post subject: |
I had trouble with my LH headlight not working.
Checked everything.
I used the wiring to the RH headlight to control relays to both headlights and fitted 100/60 bulbs.
1. old wiring draws SFA current.
2. new wiring to both headlights
3. brighter bulbs/ better visibility. _________________ Porsche 924 1984 (UK import) NA
Muz924
Joined: 21 Jul 2010 Posts: 137 Location: Melbourne Australia
Posted: Fri Aug 12, 2011 3:53 pm Post subject: |
I have just been through the dramas of getting all my lights to work on my Australian 924 which would be the same as your Euro model.
I have thread titled "pop-up headlight operation".
If you have 12V at "fuse #3" (LHS High Beam Fuse) I would have a look at the pin connection at "A18".
Disconnect the first large plug into the back of fuse box, i think its white, find pin 18 and give both sides a good clean. (clean them all whilst your in there).
Disconnect your battery first of course!
Hopefully this fixes your problem.
Cheers,
Santo _________________ 1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car) |
Nissebus
Posted: Fri Aug 12, 2011 8:34 pm Post subject: |
Thanks a bunch!
I took a look behind the fuses before I made my last post and tried to clean some connections. I used a flat headed screwdriver to clean them but I though that turning the key off in the ignition would be enough to not give me any unplesant suprises.
I was wrong.
Well, I'm not totally useless, I can be made as a bad example.  _________________ 924 -81 "The Frogmobile"
AGD931
Joined: 17 Mar 2003 Posts: 289 Location: Athens, Greece
Posted: Sat Aug 13, 2011 3:57 pm Post subject: |
similar problem to this on mine, difference is, my left low beam comes on only with a dim yellow glow, the right side comes on normally. When I put the high beam on, the right side comes on, the left side stays with the dim yellow glow.
I don't know if it is related, but when the pods are down and I flash from the indicator switch, the LED comes on but the bumper driving lights do not flash.
I dismantled everything light related on the front of the car yesterday, cleaned what was already clean, checked the grounds, couldn't find any broken wires, result NOTHING
Any ideas?
Thanks _________________ 1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia |
!tom
Posted: Sat Aug 13, 2011 4:27 pm Post subject: |
Sounds like a bad ground.
Run a meter between the chassis and the negative terminal on your light bulb, and turn on your light. A voltage reading of more than a volt or so indicates a bad ground somewhere between where the meters probes are, and hence your problem.
The wires could be failing where they bend when the light goes up and down for all you know. _________________ 78 924 NA
5-lug |
AGD931
Posted: Sat Aug 13, 2011 7:25 pm Post subject: |
Thanks for the reply. I suspected a bad ground but was not sure how tomeasure it. Thanks will give it a try _________________ 1981 931 S2
Muz924
Posted: Mon Aug 15, 2011 9:08 pm Post subject: |
| Nissebus wrote: | Thanks a bunch!
I was wrong.
Well, I'm not totally useless, I can be made as a bad example.  |
Did you get it sorted or just deeper into more trouble
I am glad you don't do work with high voltage!!! _________________ 1978 924 RoW 5-Speed (Current Project)
