Email:
Date: 1/27/00
Time: 6:53:49 PMif you have a sunroof, then either the drain tub on top of the car in the corner has come loose or split, or the tube has come out of the hole in the firewall/dash and is draining into the car versus the tray ( the wiper motor sits there) in front of the windshield.
I think you have to remove the dash to remove the corner molding. The tube runs under that molding. The best fix is too replace your sunroof seal (outer) or seal up that one drain port (which causes other problems).
The last thing it could be is a faulty windshield install.
You might be able to see the tube going into the hole in the firewall by looking up undr the dash. Or even looking in the corner under the windshield area, I think it comes out there versus the fender.
I had a 79 with a hose that had been split/pinched when it was assembled. You might run some compressed air down the drain port and listen/ feel for where it might be coming out.
Bob
