# RoW 931 porn!!! NWS warning ... (not wallet safe!)
Goto page Previous  1, 2, 3 ... 36, 37, 38
PostPosted: Thu Mar 18, 2021 11:31 pm    Post subject: Reply with quote
Bravo Steve......now that drive train should turn your new acquisition into a proper ýellowbird'.
PostPosted: Fri Mar 19, 2021 12:12 am    Post subject: Reply with quote
+1
You truly have been throwing down consistently for years and backing it up with numbers. Truly awesome
PostPosted: Fri Mar 19, 2021 2:15 am    Post subject: Reply with quote
Mike9311 wrote:
+1
Thank you Mike. Now I asked Dan some years ago, but can you get the Clubsport on the dyno as I'd love to see some data on that cars motor + mods
PostPosted: Fri Mar 19, 2021 2:19 am    Post subject: Reply with quote
Thanks Peter. The yellow CGT will have fresh running gear, don't need to take anything from the red/white turbo. The area of consideration right now is whether to put a rebuilt motor in the CGT or take it out of the turbo? Time and money wise, borrowing the turbo motor would be easier. But a lot of jobs to be done on the CGT first before I worry more on the motor option
PostPosted: Fri Mar 19, 2021 11:20 pm    Post subject: Reply with quote
Steve.....I gathered (maybe mistakenly) that the motor in the red/white was NOT the original to that car, and that you in fact had the numbers matching motor for that car tucked away.
Numbers matching should ideally remain with the car......if you are considering long term value.
PostPosted: Fri Mar 19, 2021 11:36 pm    Post subject: Reply with quote
Carrera RSR wrote:
Mike9311 wrote:
+1
I remember you asking and I promise I will get it done. There is one by my house that a good friend has used.
PostPosted: Mon Mar 22, 2021 10:37 pm    Post subject: Reply with quote
About 270chp @ a bit over 1.1 bar with morghens old k27?
That’s only about 16psi.. Nice numbers..
Thought you ran about 1.4 though? Didn’t want to dyno that high?
PostPosted: Mon Mar 22, 2021 11:14 pm    Post subject: Reply with quote
Also he never dynoed past 6000RPM, so if he'd do a 6600RPM he'd get a bit "more numbers'
Part of the reason is that Steve is running the car in a local event and there is a group limit of 280hp which he wants to stay under.
PostPosted: Mon Mar 22, 2021 11:22 pm    Post subject: Reply with quote
Averagely I have been running give or take 1.1bar for quite a while. I have ran more but its been a little det prone and too lean at the top end. Main issue for not running more is the Mittelmotor dizzy. I used to have an early 'race' version with a 2bar sensor, so I could pull timing over 1bar. Long story short, I now have the latest Bluetooth version of the dizzy but it only has a 1bar sensor, so cannot pull timing over 1bar anymore. So dyno'd at 1.1 and left the timing as advanced as possible, which it responded well to. Its now running 25deg at full rpm + full boost.
PostPosted: Mon Mar 22, 2021 11:36 pm    Post subject: Reply with quote
True
If I ran over 6000rpm it does nothing to the results under that rpm ......but it does add to a bigger 'Top Trumps' bhp number above. Nice for the bar room bragging rights, but I shift before 6000 anyway, torques are dropping away.
Page 38 of 38
