Bigger brake booster for 944 turbo brakes
PostPosted: Sat Feb 05, 2011 5:18 am    Post subject: Bigger brake booster for 944 turbo brakes Reply with quote
I converted my 924 turbo to 944 turbo calipers.
Is the 944 turbo brake booster bigger ?
I also saw a 928 one that is 10 inch. Will this fit ?
PostPosted: Sat Feb 05, 2011 7:24 am    Post subject: Reply with quote
I'd be more worried about the size of the master cylinder than the booster (though I'd take the whole thing, of course)...
I don't have any data about the sizes, though...
PostPosted: Sat Feb 05, 2011 7:27 am    Post subject: Reply with quote
Never had a problem with the std. booster, but as said above, the 951 master cylinder is essential......you now have 16 pistons to control.
PostPosted: Sat Feb 05, 2011 8:15 am    Post subject: Reply with quote
PostPosted: Sat Feb 05, 2011 7:18 pm    Post subject: Reply with quote
I now using the two step aloy 924S/944 master cylinder, it is 23,8mm (and rear 19mm)
If i look up the 944 turbo one, it is also 23,8mm but 20,6mm rear. So the difference isn't very big.
I use the car for trackdriving, so most brake power has to come from the front. So I doubt the turbo master cylinder is a upgrade for me.
(I will be using a bais valve to adjust the brake balance)
PostPosted: Sun Feb 06, 2011 2:03 am    Post subject: Reply with quote
Ah, OK then, it's good - the extra volume for the rear should help give you more to work with to adjust the bias... stock M471 setup doesn't really need any adjustment of the bias, in my experience - doesn't put enough pressure to the rear to need it reduced... even juggling the pad compounds a little...
