Cleaning coolant recovery tank
ISUnorth
PostPosted: Sun Jan 09, 2011 5:39 am    Post subject: Cleaning coolant recovery tank Reply with quote
Probably covered in an older post but I found a good tank cleaner. I tried dishwasher soap and hot water which flushed some of the crud out. Was looking at maybe using muriatic acid but saw some Zinsser paint brush cleaner in the same isle at Menards and bought a quart. It just dissolved all of the slimy brown crud in just a few minutes. I figured it’s pretty safe on the tank since it’s for cleaning brushes and most are synthetic with plastic bases and handles. Its water and soap clean up to. Wish I had a before picture, below is the after. Also maybe wish I hadn’t been so quick to buy a new tank to put in. I was just trying to clean the old one and replace it after I got the system flushed.
Captain_Kirk
PostPosted: Thu Jan 13, 2011 9:03 am    Post subject: Reply with quote
I cleaned out my brake fluid rez when I changed all the brake fluid. The gunk in the bottom was black. I used brake cleaner and swished it around and an air hose to get it out. Now it's all clean like new and makes my coolant tank look ugly so it's on the list to do.
Yours is purdy.
1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body
Nobbi
PostPosted: Tue Mar 01, 2011 6:49 am    Post subject: Reply with quote
Just got a new one from porsche for my 944 cabby.85.- Euros,no hassle...
Nobbi
NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1969
PostPosted: Tue Mar 01, 2011 7:45 am    Post subject: Reply with quote
Capn Kirk the tank has rust and crud in there he needs a good
cleaner. Brake cleaner would be a no go .. jus my 2 cents.
