Posted: Wed Oct 06, 2010 3:08 am Post subject: Cheaper & alternative parts list |
Came across this list of alternative parts on another site.
Unashamedly copied & pasted it here as a reference and because it may get pulled for commercial reasons. Although aimed towards 944 & 951 owners, many are common on the 924S and some used on a 924 or 931 or possibly for upgrades.
Engine
Fuel pressure regulator
FPR, 2,5bar
944/951 85.5-89
0 280 160 227
944 110 198 04
100€
Bosch
FPR, 3bar
951 85.5-89
BMW 325 E30 85-91
0 280 160 258
100€
Bosch, for chipped car
0 280 160 249
100€
FPR, 3,8bar
S2
0 280 160 287
Bosch
Cut-Off Valve / BOV / Bypass
951
Saab 9-5 (part# 4441895)
0 280 142 110
30e
Bosch
951
Newer Audi / VW
0 280 142 115
49€
Bosch
Air filter
944 82-89
VW Corrado 1.8 16V 4/89-7/92
6€
Radiator fan switch
3-pole 95°-85°+102°-92°C
82-91
Audi 100 88-94
7.5635
Facet
Seat Ibiza 93-94
VW Golf II 85-91
Volvo 400-s
Expansion tank cap
17mm/15lbs
82-85.0
Alfa 33 1,7-16V 87-92
Audi 100 67-78
Ford Granada 2,5-Diesel
Throttle position sensor
944 82-89
0 280 120 308
944 606 113 01
Bosch
951
Volvo 440 1.7 Turbo 9/87-7/91
0 280 120 400
951 606 113 00
Bosch
Volvo 960 2.0 8/90-9/93
Crank pilot bearing
6202-2RS/C3/FAG
FAG
DME temperature sensor
DME, blue M12x1,5
82-91
BMW 316i
0 280 130 026
944 605 125 00
Bosch
Fiat Uno Fire-ie/Turbo/ie
Opel Astra 8V injection
Volvo 700-s Turbo -84
Knock sensor
951, 944S, 944S2
Ford Escort 1.6 80-85
0 261 231 006
Bosch
Citroen BX 19GTi 16V 87-93
Saab 900i-16V 85-93
Speed / Reference sensors
Speed / Ref. Sensors
82-91
0 261 210 003
8v 2pce, 16v 1pce
Thermostat
83°
82-88
G4000-23460
Wahler
234-82
Motorad
1026-80
Vernet
Thermo-pneumatic valve
951
Audi 100 77-91
058 131 851 A
058 131 851 A
Idle control valve, ICV
944/951 85.5-89
Peugeot 405 1,9GRi
0 280 140 501
Bosch
Renault R19 1,7iKat
Renault Clio-I 16V-1,8/2,0
Volvo 740 B200ET/230ET -87
S2
0 280 140 531
Bosch
Cooling hose
951
Peugeot 205 D/1,6/1,9 waterpump
951 106 239 01
Oil filter
82-91
l
OC142
944 107 201 90
Knecht / Mahle, orig.
OC75
Knecht / Mahle, longer
W719/22
Mann
H 14 W 25
Hengst
R 128
Tecnocar
FT 5239
Fiaam
PH-6941
Fram
Fuel system and exhaust
Oxygen sensor, lambda
85.5-91
0 258 003 012
951 606 135 0
Bosch
Fuel pump
944 85.5-88, S/S2
Alfa 75 1,8 Turbo 87-89
0 580 464 028
944 608 102 06
Bosch, green
Fiat Uno Turbo-1,3ie/1,4ie 85-92
Renault Espace 2,0i/2,2i/2,8i 91-96
Volvo 343 B19E/B200E/B200F
Fuel pump
944 82-85.0, 951
0 580 464 021
944 608 102 04
Bosch, blue
Fuel filter
M14 threads
82-91
BMW 320i 4.79-82
BMW 323i 9.78-8.79
BMW 518i 75-79
Fuel tank cap
82-91
Audi, Passat, Golf I
Transmission
Clutch master cylinder gasket
82-91
PBR K7664X
Clutch slave cylinder gasket
82-91
MB W123/124 (FAG) 76-95
PBR 1021S
Has to be modified slightly
Front axle and steering
Balljoint, lower
Steel control arm
82-85.0
VW Golf I
12€
Control arm
Steel control arm
82-85.0
VW Golf I
23€
Shock absorber cover rubber
82-85.0
BMW 316/318/320 E21 75-82 front
Mercedes Benz W124 front
Nissan Sunny N13/B12 rear
VW Golf 73-91
Wheel bearing, front
82-86
VKBA 1400
SKF
87-91
VKBA 956
SKF
Outer
87-91
L68149 99402 L68111
Timken
Inner
87-91
1-M12649 1-M12610
Timken
Sealing
87-91
ERIKS RST 45 62 10
Powersteering belt
L=950mm
82-91
Audi 80 1,3-1,8 86-92 LA/VP
Honda Civic 1.2/1.3 80-83 LA/VP
Seat Toledo 1.6-2.0 -93 LA
VW Golf 1.6/1.8 86-91 LA
Opel Vectra B TurboD-1,7 96- OT
Tie rod, outer
Powersteering
82-86
Golf I, Jetta I, Caddy I
171 419 812
944 347 333 00
TRW
Manual
82-83 94DN402644 until
116 020 3226
944 347 333 00
Meyle
10251
944 347 333 00
Lemförder
Rear axle
Wheel bearing, rear
82-85.0
VW beetle 1302/1303
VKBA 592
SKF
85.5-91
305988
SKF
527243BE
FAG
Rear control arm
82-85.0
VW beetle 1302/1303
CV joint
82-86
VW Transporter 68-90, Syncro 85-90
couple mm wider
CV joint cover rubber
82-91
82-91
BMW 700
Wheels and brakes
Brake caliper seals
Front
944 82-89
Audi 100 5E-2.2/TD-2.0 1977-7.79
ATE
Peugeot 505
Peugeot 604 front
Brake caliper piston
Front
944 82-89
Peugeot 504 78-82 front
ATE
Peugeot 505 front
Peugeot 604 front
Brake master cylinder
82-91
MB W123
Emergency brake shoes
82-91
BMW e28 525i 81-88
Re-use old springs
Handlever system, pedal cluster
Brake and clutch pedal pad
85.5-91
Golf II
Body and interior
Sun visor clip
82-91
Golf III
3B0 857 561 BY20
Grey
3B0 857 561 BB41
Black
3B0 857 561 B8YS
Beige
Sun visor cover-clip
82-91
Golf III
3B0 857 563 BY20
Grey
3B0 857 563 BB41
Black
3B0 857 563 B8YS
Beige
Electrical equipment
Battery
64Ah
82-91
Audi 100, gasoline 75-90
Seat Ibiza, 93-98
VW Golf III, gasoline
DME-relay
82-91
Opel
4RP 008 189-051
Hella
Headlamp
82-91
Audi 80 5/75 – 7/76
20e
VW Golf I
VW Passat 5/73 – 7/77
Voltage regulator
115A alternator
82-91
Audi 100, 81-92
1 197 311 040
Bosch
BMW 300s, 81-90
Ford Sierra, 82-93
VW Golf 8.81-91
Alternator
90A
82-85.0
Ford Scorpio 2,0-OHC/Diesel/TurboD 90A
Ford Sierra 1,3-2,0 OHC 90A
Alternator
115A
85.5-91
0 120 468 005
Bosch, or 0 120 468 004
1987 Volvo 2.3L Turbo 740
Alternator brushes
5x8x15mm
82-85.0
MB W123 76-80
Bosch
VW Golf 74-7.81 Bosch
Volvo 200-s 74-8.81
Alternator brushes
5x8x19mm
85.5-88
BMW 300s 81-90
Bosch
Ford Sierra
MB W124
VW Golf 8.81-91
Alternator sliding ring
82-85.0
BMW 300s 75-81
Bosch
MB W123 76-80
VW Golf 74-7.81
Volvo 200-s 74-8.81
85.5-88
BMW 300s 81-90
Bosch
Ford Sierra
MB W124
VW Golf 8.81-91
Alternator belt
L=735
82-85.0
Peugeot 605 TD-2.1 -94 LA
Rover 75 1,8 LA
Rover Freelander 1,8 LA
Alternator belt, cars with AC
82-85.0
BMW 535/540 E39 ilmastointi
Mazda 626 1.6/2.0 85-87 LA/OT
Toyota Carina E 2,0 -93 LA
Toyota Picnic 2,0 VL/ei ILM
Alternator belt
6x725mm
85.5-91
Nissan Sunny GTi-16V 1,6/1,8 86-91 LA
Nissan Bluebird 1.6-2.0 86-88 LA
Nissan Prairie 2.0 88-89 LA
L=1005mm
85.5-91
Citroen Jumper 2,5D/TD/TDi LA+OT
MB 208D/210D/308D/310D -95 LA
MB 408D/410D -95 LA
Peugeot Boxer 2,5D/TD/TDi LA+OT
Windshield washer pump
82-91
VW Golf I/II/III
Reverse light switch
82-91
MB 100D
MB 207D-310D (601/602) 80-95
MB 407D-410D (611) 82-95
Ignition coil
82-91
0 221 118 322
944 602 115 0
Bosch
Distributor rotor
944/951 (ei S/S2)
0 300 900 169
944 602 901 01
Beru (EVL 169)
Turn signal, side
82-91
Golf I / II
Starter motor brushes
Audi 100
Spark plug
944/951 82-91
Bosch WR7DC
NGK BPR6ES
Spark plug
S2
NGK BPR7ES
Ignition control unit
944S/S2
Ford Escort 1,6i 86-90
Bosch
Opel Corsa 1,2N/1,4 87
Saab 900i-16V 85-93
Seat Ibiza 1,5i
Turn signal relay
82-91
Audi A6
0 335 200 041
Bosch
BMW 316-320 9.79-90
Ford Sierra 82-93
Opel Astra
VW Golf III 91-98
Distributor cap
944/951 (NOT S/S2)
1 235 522 325
944 602 251 00
Bosch
0 330 920 414
Beru (VK 442 S)
Distributor cap
944S / S2
Volvo B200/230
Distributor dust cover
82-89
1 230 500 219
944 602 803 00
Bosch
Ignition switch
82-85.0
Golf I / II 74-92 _________________ World`s quickest 924 2L slushbox
Allan @ DTA wrote: | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
