The 80 NA build log
PostPosted: Sat Aug 21, 2010 3:09 am    Post subject: Reply with quote
I'll check on what I have for alum and get back to you. How fast do you need it?
PostPosted: Sat Aug 21, 2010 3:21 am    Post subject: Reply with quote
Not fast. This is for the UWB project. I already have a solution, but this is a heckuva lot purdier
PostPosted: Sat Aug 21, 2010 3:22 am    Post subject: Reply with quote
Made this too, but it needs tweaking i.e. not perfect.
PostPosted: Sat Aug 21, 2010 3:27 am    Post subject: Reply with quote
Thanks, that will give me time to tweak the mount holes. On the first one they were off. Sometimes its hard to get all the bolt patterns right. I scanned the dist mount, projected the circles in Corel, converted to dxf, and brought it over to the cad. Something was lost in the technique (my eyeballing the circles in Corel) but I had to try. It got me close.
I thought it looked cool but was sad to know it will be between the head and firewall!
PostPosted: Sat Aug 21, 2010 1:58 pm    Post subject: Reply with quote
Hey yea I hung them just to get a look and your right
the damn doors are off so I talked to a painter and he said to wet
sand till really smooth then since its the build coat I could either add more overly reduced base coat lightly or add something to the clear and shoot
itwith all the panels so thats what Ill do. Im confident as I had to do that to the hood as I didnt get all the laquar thinner out of the gun inbetween the sealer and base and it curdled after the clear build coat was on. If
you look at the hood pics its fine now.
I posted some pics tonight of the doors on as well and you can see
you were right bout sghooting metalics and gravity.
PostPosted: Thu Oct 14, 2010 5:54 am    Post subject: Reply with quote
Just tidying up a bit of info ...
http://www.924board.org/viewtopic.php?t=26176&highlight=80na
...and adding these pics for the hybrid composite tubular aluminum/carbon shift rod in keeping with the theme of lightening everything that isn't usually lightened.
This is Version 1 for testing. Shown prior to carbon wrap during 'floor' testing. The 2nd picture is the carbon wrap applied using techniques to prevent galvanic action (corrosion) between the carbon and aluminum.
This significantly increased the stiffness of the aluminum and couldn't be done without it. The wrap was vacuum consolidated to get a better resin to fiber ratio (higher strength) and cured at higher temps.
Peel ply being taken off the carbon.
It is in the car now and shifts totally normal and nice (as it sits ) and at about 1/3 of the weight if memory serves.
PostPosted: Fri Mar 30, 2012 3:17 am    Post subject: Reply with quote
Teaser pic. More to follow. I have been busy and thus not around much accept for the occasional lurk. However, new effort is being made to get this puppy rolling
Pic is of the temporary rear wheel adapter for the civic wheel being machined. Also working on a one piece AL engine mount
PostPosted: Fri Mar 30, 2012 3:24 am    Post subject: Reply with quote
Here is the distributor cover mounted. Just realized I never posted it. Also noticed Min made a two piece welded version (nice idea BTW)
PostPosted: Sat Mar 31, 2012 1:43 am    Post subject: Reply with quote
Backside of the adapter in the fixture. Should have it test mounted at the end of today.
PostPosted: Sun Apr 01, 2012 2:06 am    Post subject: Reply with quote
Even with the new temporary adapters the savings is -8lbs at each side at the rear! This is now close to -40lbs off the front end unsprung and another -16lbs off the rear. All hardware included in the comparison.
-56 lbs (US) of unsprung weight removed total. Not to mention inertial savings yet to be calculated.
More pics to follow
tyfighter123
PostPosted: Sun Apr 01, 2012 11:13 am    Post subject: Reply with quote
Looking great keep the pictures coming they are very nice!
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
PostPosted: Sun Apr 01, 2012 12:52 pm    Post subject: Reply with quote
Thanks!
Here is another one. The adapters are already bolted on to the rear but the car won't be dropped down just yet.
PostPosted: Mon Apr 11, 2016 2:07 am    Post subject: Reply with quote
Some updates...engine is finally in.
Close up of cam gear balancing version 1.
PostPosted: Fri Sep 09, 2016 11:24 pm    Post subject: Reply with quote
Found the original 1986 pics of the engine bay...brutal
A rescue and a warning. The rescue is obvious but the warning is for the fold over sheet metal wiring harness holder(s). Don't let it cause an engine fire. The car was bought this way. I believe the previous owner had the car in a Chicago parking garage and the engine had an electrical fire. The fire department came and put it out. Resulting in ....
Its too bad this car can't roll for 92Forty. Its close but not close enough. The car has been stored inside ever since. Only one seat has seen recent use in the '82 931 while the 931 seat gets restored
The interior is pretty much mint. Once seat had some damage (not sure why). Original dash Stored with salt block that was pulled out frequently to be dried out in oven.
PostPosted: Mon Mar 15, 2021 12:44 am    Post subject: Reply with quote
Cleaning and organizing yesterday. Pulled this one out from the back where it was blocked from working on it. Replaced it with the BMW 2002 on a rotisserie back there for the moment. Wish the wheels were larger so it rolls easier but this rig is nice. This one is so close to rolling it's not funny and yet... 931 priorities
Page 2 of 3
