Running VERY hot at Idle
Finn99
PostPosted: Wed Jul 21, 2010 5:49 am    Post subject: Running VERY hot at Idle Reply with quote
hey guys....not sure if I should post this here or in another part of the forum but here goes.......I've just replaced my water pump but my temperature gauge is going all the way to the limit after about 5-10 min of running at idle....I took it out for a drive and about 5 minutes in, it did the same....any ideas on what the issue might be?
It's a normally aspirated 1977.5.
cheers,
Juha
datatrain
PostPosted: Wed Jul 21, 2010 5:52 am    Post subject: Reply with quote
Is your thermostat stuck in the closed position. Is the belt tight on the pump. Did you bleed the system after you refilled the radiator ?
'78 924 NA with Collector plate
33 year old car, with me for 21 yrs
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
CorsePerVita
PostPosted: Wed Jul 21, 2010 6:01 am    Post subject: Reply with quote
+1 to datatrain. Make sure no bubbles in the system and everything else. Old worn out thermostat will start getting stuck or not open.
You can drop the thermostat in some almost/not-quite/on-it'swaytoboiling water and see if it GRADUALLY opens. If it doesn't, your thermostat isn't opening.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
Finn99
PostPosted: Wed Jul 21, 2010 6:26 am    Post subject: Reply with quote
thanks for the quick responses...I'll try these tips asap and report back when done...I wonder if this has anything to do with my 'hot start' problem?!? The car starts on the first turn every time when it's nice and cool but requires some effort after running for awhile....
PostPosted: Wed Jul 21, 2010 7:00 am    Post subject: Reply with quote
+ make sure the rad fan/s are running.
PostPosted: Wed Jul 21, 2010 7:07 am    Post subject: Reply with quote
. . .first.
Finn99
PostPosted: Wed Jul 21, 2010 7:12 am    Post subject: Reply with quote
will do...these are great suggestions and inline with my thinking....it's strange that it just started happening....got the water pump replaced, put maybe 100 miles on it in the coming weeks...then it sat for 2 or so weeks while I was away and all of a sudden, I turned it over, let it run and you could see the guage go into the red....
Slam
PostPosted: Wed Jul 21, 2010 9:40 am    Post subject: Reply with quote
Did you make sure to fill the block before popping the thermostat in? You'll never get enough coolant into the system just by filling the overflow tank with a cold engine and closed thermostat.
And check out the points stated above.
Also, a very lean mixture leads to overheating, too.
'84 944 - all-weather workhorse.
'83 944 - still looks like ass.
'87 944 - wifey's DD, alive and well.
'80 924 - tuned by son #1.
'78 924 - blown up by Scottie.
'77 924 - gift from friend. Future project...
Some wrecks
Finn99
PostPosted: Thu Jul 22, 2010 1:16 am    Post subject: Reply with quote
thanks for the advice....it's greatly appreciated. The Water Pump was professionally installed so I hope they did all the usual necessary things.
the battle continues....I will hopefully get to it this week.
PostPosted: Thu Jul 22, 2010 1:28 am    Post subject: Reply with quote
I would assume NOTHING, regardless of how reputable the shop may be. You need to verify ALL assumptions, including the t-stat installation.
Finn99
PostPosted: Thu Jul 22, 2010 1:36 am    Post subject: Reply with quote
very true indeed. Especially with these cars. I'll go through a check list of items to trouble shoot based on all the good advice and see how we do...
Finn99
PostPosted: Tue Aug 17, 2010 1:24 pm    Post subject: Reply with quote
finally got to work on this issue while the wife and baby were away....after going down various routes of trouble shooting, it turns out that the thermometer was only partially working after doing the water heating tests.....new thermometer it is!
thanks for the help guys!
PostPosted: Tue Aug 17, 2010 1:42 pm    Post subject: Reply with quote
Thats what were here for.. we stand buy our cars & help guys
like you out.
PostPosted: Tue Aug 17, 2010 8:05 pm    Post subject: Reply with quote
Congrats on challenging the assumptions and finding the problem!
Finn99
PostPosted: Wed Aug 18, 2010 12:33 am    Post subject: Reply with quote
it was actually fun getting to wrench for a bit.....I appreciate all the help once again! I'm sure I'll find something else to get answers for!
