radio problems
samurai924s
PostPosted: Sat Jun 15, 2002 6:27 am    Post subject: Reply with quote
i was installing my radio and like and idiot forgot to diconect the battery. i think i shorted something out, but i dont know what. the fuses look good, but just incase which fuse is for the radio. is there some sort of inline fuse somewhere in the wiring? its got me completely confused.
gohim
PostPosted: Sun Jun 16, 2002 2:05 am    Post subject: Reply with quote
How many fuses are in the line, and where they are located depends on how your radio was installed.
What kind of radio were you installing or trying to install?
Was the Porsche Factory Wiring already in the car used, or a harness from the radio's manufacturer?
Porsche installed a relay for the radio, to reduce the load on the ignition switch. If you, or your installer did not use the Porsche Factory Wiring, then the relay, and the factory fuse location would not be important. The factory relay and wiring are not "hot" when the ignition switch is off, but are when the key is in the accessory position.
If you or your installer a Non-Porsche Factory Radio, and Non-Factory Wiring, where the fuse/s would be, and where the power for the radio are connected must be traced out manually.
