Email: vaughan@vaughanscott.com
Date: 1/21/00
Time: 6:56:50 PMMost likely is a bad sender, as I recall; this bad sender will give the same response as grounding the signal wire.
Bad news is the sender is not cheap, and a PITA to get to (back of the head, up against the firewall). However, it is kinda important to know what your oil pressure is...
Vaughan
