UT-CIS Sticky
PostPosted: Thu Aug 12, 2010 8:51 am    Post subject: Reply with quote
Nein37 wrote:
Also... I bet your engines grenade before mine.
I'll take that bet.
And, I was serious about your factory WUR. . .you're risking rupturing the diaphragm. . .under boost. . .at high RPM. . .
  • Wei�e (1987 924S) - 931 S3
Nein37
PostPosted: Thu Aug 12, 2010 1:14 pm    Post subject: Reply with quote
Is the GTS WUR different from the stock 931 WUR?
1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears.
PostPosted: Thu Aug 12, 2010 2:16 pm    Post subject: Reply with quote
Just telling ya what the FSM says, my brother. If you like the factory WUR, Brian Leask can rebuild it with a stronger diaphragm. Seems like reasonable insurance to me.
rasta
P.S. If you do this, the bet is off.
Nein37
PostPosted: Thu Aug 12, 2010 2:50 pm    Post subject: Reply with quote
Thanks for the heads up Rasta, I didn't realize the adjustable units utilized a different diaphragm. BTW I'm only running 12psi currently... I've decided there is no good reason to push the engine too hard.
stevekat
PostPosted: Fri Aug 13, 2010 3:25 pm    Post subject: Reply with quote
Our engines don't grenade, they Chernobyl. I think you'll be happy with your UTCIS once you get a properly working unit in place.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
gegge
PostPosted: Sat Aug 14, 2010 1:08 am    Post subject: Reply with quote
The GTS didnt have a WUR. Only a simple vavle with a high or low setting. Very digital
Carl Fredrik Torkildsen
PostPosted: Sat Aug 14, 2010 5:13 am    Post subject: Reply with quote
wow...could we replicate that thing? i'm interested...i plan to run 1 bar as standard boost and i really dont want the WUR to crap on my engine.
gegge
PostPosted: Sat Aug 14, 2010 7:21 am    Post subject: Reply with quote
Easy. But you have to choose; milage or power.
Buy a 3 bar (adjustabe?) fuel pressure regulator and you are close.
PostPosted: Mon Aug 16, 2010 12:51 pm    Post subject: Reply with quote
This is an interesting idea. You could have an old-skool type choke. . .it would just have to swing from 2.5 to 3.5 BAR.
gegge
PostPosted: Mon Aug 16, 2010 6:35 pm    Post subject: Reply with quote
Sorry, I was wrong. The GTS has a WUR located on top of the intake manifold.
Cold: 2,2 bar
Warm: 3,65 bar
Warm at WOT: 2,6 bar
PostPosted: Mon Aug 16, 2010 7:53 pm    Post subject: Reply with quote
ok then...how does the GTS WUR differ from the 931 WUR?
does it have a better diaphragm? does it work in a different way?
Nein37
PostPosted: Mon Aug 16, 2010 11:45 pm    Post subject: Reply with quote
Inquiring minds want to know.
PostPosted: Tue Aug 17, 2010 12:35 am    Post subject: Reply with quote
Pelican shows the 931606107X part available, subject to core charge. Only $967.50!
PostPosted: Tue Aug 17, 2010 1:27 am    Post subject: Reply with quote
ha ! nice price.
however we would want the 105X as thats pre 81 and thats for the high boost applications...however..they have the same part numbers..and that means chances are the WUR is identical for the 931 and 937/GTS
PostPosted: Tue Aug 17, 2010 2:09 am    Post subject: Reply with quote
Oops, misread the PET, as did you, Morghen. I believe the CGT motor is the M31.05, which does appear to use the "standard" 931 WUR.
Per our Tech Section, the GTS and GTR motors were M31.06 & M31.07, not appearing in the PET page shown.
A more likely candidate for the GTS would be the 930 part, also horizontally mounted.
Page 3 of 6
