At my whits end !!! Help !!
frozen-solid1
PostPosted: Wed Feb 20, 2013 11:23 am    Post subject: At my whits end !!! Help !! Reply with quote
OK,
heres the deal, got fuel, got spark, timing is right, still wont start !! have done all the checks the manual gives. Are there any 931 hero's in the Portland area that can help me get this turbo started ?
This project still has a long way to go before its road ready, but have to get the engine sorted out before I go on to other things. Any help would be awesome.
As for me and my house we will serve the Lord.
sharpie
PostPosted: Tue Feb 26, 2013 7:37 am    Post subject: same problem Reply with quote
Just found mine didnt have compression so i found my intake valves were leaking and i only had 60 psi comression
PostPosted: Tue Feb 26, 2013 9:18 am    Post subject: Reply with quote
How'd you find your intake valves leaking and not say, the piston rings? Did the engine smoke a bit?
PostPosted: Tue Feb 26, 2013 9:33 am    Post subject: Reply with quote
Give her a shot of ether and see what she does.
sharpie
PostPosted: Tue Feb 26, 2013 11:45 am    Post subject: cylinder leak tester Reply with quote
there $40 at harbor frieght they screw into your spark plug hole and you put a compressor to it and you hear where they leak ie if its a valve it comes from the intake or exaust if its a head gasket or rings it comes from the oil or coolent.
frankg
PostPosted: Mon Jun 03, 2013 4:33 pm    Post subject: Reply with quote
If it has been sat for a while the piston rings might be seized so put a little oil down the bores and leave them for a while to soak.
Question is did you have it running before or is the first time you have tried? As said above, engine could be tired and need the head reconditioned and rings replacing - what mileage has the engine done????
Have to say the 931 Turbo has been one of the most reliable engines I have ever had the pleasure of owning !!
Life is about living, we all leave soon enough.
PostPosted: Mon Jun 03, 2013 8:31 pm    Post subject: Reply with quote
To the OP, what year is your 931?
In the meantime, two threads you should read first:
http://www.924board.org/viewtopic.php?t=28790
http://www.924board.org/viewtopic.php?t=22724
