924 Turbo clutch
Guest
PostPosted: Mon Jan 17, 2000 3:18 pm    Post subject: Reply with quote
Email: jwalin@iupui.edu
Date: 1/17/00
Time: 4:18:02 PM
I need an old junk 924 Turbo clutch+pressure plate+TO bearing. I am trying to put a 944 transmission in a 78 924 and need to see if I can use these parts.
