brupska
Posted: Fri Feb 19, 2010 2:58 pm Post subject: IT LIVES AGAIN!!!!!!! |
| Well after 6 months my 81 924 NA Weissach edition lives again!!!!! I intalled twin webers, fuel pump and FP relay, fuel lines,FPR, retorqued the head, new starter, and had to epoxy the distributor crank trigger plug. After all that, it would crank but no fire!!! I checked the timing and the Cam was 180 deg out. I fixed that and still no fire. I cleaned all the plugs, epoxied the dizzy cap (Cracked)!!!! Now it fires right up!!! It is missing on #2 cyl though. I am buying a dizzy from a member on here. A new dizzy cap and rotor are on their way. The FPR wouldn't allow any fuel thru so I had to rig that and new one is on its way. Now I need to run the valves, change plugs and wires, and Buy air filters!!! It has been a long journey and I can't thank everyone on here enough!!! Oh the temp gauge is pegged so I think I need to get all of the air out of the cooling system too!! THANK YOU ALL VERY MUCH!!!! So now another Toofah is going to be on the road soon!!!! Brad |
