KKK Turbo from 1.8t Audi A4
PostPosted: Thu Feb 04, 2010 1:05 pm    Post subject: KKK Turbo from 1.8t Audi A4 Reply with quote
Anyone look into the similarities of these turbos?
Has a similar 3 bolt flange, but is internally wastegated. How close is this flange to ours?
PostPosted: Thu Feb 04, 2010 6:27 pm    Post subject: Reply with quote
Are those your pics ... looks nice and shiny.
PostPosted: Thu Feb 04, 2010 7:40 pm    Post subject: Reply with quote
do you want to use the hotside of it? because the coldside is crap...
Ruby-sh 924
PostPosted: Fri Feb 05, 2010 12:24 am    Post subject: Reply with quote
Looks way too small...but should be easy to figure out by ordering that gasket. Should be cheap, may be $5-6, so not a lot of expense to find out...
PostPosted: Fri Feb 05, 2010 12:40 am    Post subject: Reply with quote
The k04s are supposed to be decent from what I've heard..
I was just thinking if these are similar we'd have some additional turbo options..
PostPosted: Fri Feb 05, 2010 12:58 am    Post subject: Reply with quote
no..they are crap...cant deliver pressures much above stock...and therefore i think they cant deliver much flow...i think that they are ranked for 240-250HP..?
i know a guy with a 1.8T passat trying to run 1.x bar on that engine and the effect was simple, crap.
it put out 1.8 bar at 2500 rpm until 3500 or something...then it dropped to 0.6 or so at redline....so...very unlinear...the car was slow and it never did two identical 1/4mile times.
Ruby-sh 924
PostPosted: Fri Feb 05, 2010 3:01 am    Post subject: Reply with quote
Can't imagine the k04s on the s4 are "crap" with 400+ hp
PostPosted: Fri Feb 05, 2010 5:08 am    Post subject: Reply with quote
than perhaps we are not talking about the same turbine.
I'm talking about the factory turbocharger on the 1.8T VW/audi engines 150HP i think...
Ruby-sh 924
PostPosted: Fri Feb 05, 2010 6:50 am    Post subject: Reply with quote
morghen, I am talking about that motor/turbo but an upgrade. I'm thinking if the stock one would fit, then an aftermarket one for that car should fit as well.
PostPosted: Fri Feb 05, 2010 6:52 am    Post subject: Reply with quote
The 3-bolt flange is either too small, or that's about a 6" exhaust gasket shown in the first post.
PostPosted: Fri Feb 05, 2010 6:55 am    Post subject: Reply with quote
Well the exhaust flange includes the internal wastegate.. so it is quite large.. Not sure what the exhaust inlet size is though..
Rocco R16V
PostPosted: Fri Feb 05, 2010 10:15 am    Post subject: Reply with quote
thats using two of 'em
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
PostPosted: Fri Feb 05, 2010 11:28 am    Post subject: Reply with quote
Oh I know, but guys swap them onto the jettas and push 275 through 'em
alexvex
PostPosted: Fri Feb 19, 2010 10:11 am    Post subject: Reply with quote
Stock 1.8T turbo is called a K03, upgraded unit (from the 2.7tt RS4) is the K04 like Flosho is talking about
--Alex--
1992 Porsche 968 (VW 2.5L I5 Turbo swap in the works)
1995 Audi 90 Quattro Sport (4.2L V8 Swap)
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
PostPosted: Fri Feb 19, 2010 7:48 pm    Post subject: Reply with quote
that makes sense.
Ruby-sh 924
