1988 924S Special Edition
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale
Philly924S
PostPosted: Sat Feb 23, 2019 6:21 am    Post subject: 1988 924S Special Edition Reply with quote
1988 924S 1 of 500 in US
69K miles
alan dot stark51 at gmail dot com
$ 4500.
https://imagizer.imageshack.com/img922/1587/NnmQ13.jpg
https://www.pca.org/news/2018-10-16/why-1988-porsche-924s-se-porsche-we-should-all-be-shopping
https://www.thetruthaboutcars.com/2016/09/why-you-should-buy-a-porsche-924-and-which-one-is-for-you/
Scroll to bottom of article
This is a great driving car. It has nearly perfect balance. Equal weight front to back, right to left. You will not be overwhelmed by HP (160 ponies), but you will be seduced by how comfortable this car is to drive at speed. Balance is the word that comes to mind. I find driving this car intoxicating, itís that much fun. This car comes alive above 4K rpm. And, lets face it, at this price, with the maintenance this car has had, it should be tons of fun for a long time.
I replaced the soft fuel lines, including line from the fuel supply to the injector fuel rail.
I removed the fuel injectors, sent them to Witch Hunter Performance for rebuild and flow test (Results Below). Witch Hunter strips the paint off the injectors as part of their cleaning process. I painted mine Red to match the silicone hoses.
Replaced all vacuum hoses with red silicone hoses. There is one stock hose (from the ICV to the J Boot) custom hose from Porsche. I was so impressed with the factory hose clamps ( Oetiker) that I sourced and used them in the rebuild.
I ďnotchedĒ the dipstick bracket. The dipstick tube has an O ring at the bottom where it enters the engine block (Pix below). This O ring is often overlooked and not replaced. This can result in a loss of vacuum. (Old Porscheís seem to be sensitive to vacuum). As you can see, mine was deteriorating. By notching the tube bracket, it can be removed and the O ring replaced without taking apart the top of the engine.
I cleaned the distributer, replaced the cap, rotor, and spark plugs (old ones looked fine, evenly colored, no deposits).
DME replaced with: Focus 9 Solid State Relay with Pump Prime. First, itís nice to have a solid state relay. When you turn the key to the run position, prior to turning to start the engine, the relay starts the fuel pump for 3 seconds. This pressurized the fuel rail and makes starting easier. The engine does not have to spin to get pressure up.
http://www.ftech9.com/new-products/993-ssr-pp
THE GOOD:,
1 of 500 in US (aprox 500 additional cars world wide)
Has medallion on dash
Correct light weight fabric on doors
Factory increased Compression Ratio
Factory Increase Torque
M030 Suspension
Seats in car NOT original. (I have one original seat that came with car. Itís in poor shape). The drivers seat in the car has been recovered in cloth, not original.
Everything works (unless described below). Headlights pop up and work, turn signals, fan, radio (I have original faceplate), gauges, switches, all exterior lights work.
THE NOT SO GOOD
A/C dosenít work (frankly, Iíve had multiple Porscheís and the A/C didnít work in any 30 year old car).
This car is no garage queen. Frankly, I find that acceptable, I donít worry about parking lots.
The dash has the usual cracks. The clock does not work.
The keys have a difficult time in the ignition. I have a replacement lock and key set that comes with the car. I wanted to install it when I cleaned the grounds for the dash lights. The dash lights donít work, but all other and other console lights work. (in old cars, when I see electrical problems, I think: grounds...just me.)
Currently the car has an indwelling key. (My brother-in-law took a working key and made a top that looks like it came from the factory. This key stays in the ignition and always works, Removing the key will result in time to fiddle with the lock to get the key past lock. The fix is relatively easy R/R, parts are included with car:
http://www.clarks-garage.com/shop-manual/elect-25.htm
So, thatís it. Great driver, good bones, and cheap!
[img][/img]https://imagizer.imageshack.com/img924/1729/j9fARg.jpg[img][/img]https://imagizer.imageshack.com/img921/1113/5R0Fw5.jpg[img]
[/img]https://imagizer.imageshack.com/img924/2620/UseK5l.jpg
https://imagizer.imageshack.com/img923/4997/RJS0i9.jpg
Thanks for looking
Alan
1961 356 Cabriolet
1981 911 SC
1988 924 S
Philly924S
PostPosted: Sun Mar 17, 2019 12:57 am    Post subject: Car is SOLD Reply with quote
Car is SOLD
Thanks for looking
1961 356 Cabriolet
1981 911 SC
1988 924 S
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 10 Hours
