Try One More Time: Discussion Web
PostPosted: Sun Jan 16, 2000 8:50 am    Post subject: Reply with quote
Email: webmeister@924.org
Date: 1/16/00
Time: 9:50:54 AM
This is a Frontpage web. For some reason after a few posts it has been 'mangling' the message threads. I have been roaming the Frontpage Usergroup and see only that (as is typical of MicroSoft apps) there are strange and magical inter-relationships, none of which are documented for poor schmucks like me.
So: we'll try build number 3 with a few slight changes. Be patient. John
PostPosted: Fri Feb 11, 2000 8:31 am    Post subject: Reply with quote
Date: 2/11/00
Time: 9:31:11 AM
Well, it seems to be working well. So I am hesitant to mess with success! But, to be useful you all have to be able to focus in on information quickly. And to help you do that I need to 'weed' every-so-often.
Shortly, I will attempt (again) to edit the messages and leave only the most pertinent and informative or recent. An 'archive' is a possibility but is easier said than done.
If you have posted something for sale and sold it please post a 'reply' to your original message indicating. That way I will know that message does not need to be kept.
I have been asked about more/better links between the "924 Garage" (sections) and this "Hanging Out at the Garage" discussion forum. Because this forum gets messages posted form 'outside' and because of the increased exposure to corruption and because of the limitations of the software and server, the two sites are as seperate as possible. If something corrupt the links on this subweb I don't want to chance it messing up the 14Megs worth of work on the Garage
Cheers, John
